[gdal-dev] TypeError Wrong number or type of arguments for overloaded function 'CoordinateTransformation_TransformPoint'.
zerovirus123
briansia93 at gmail.com
Tue Jun 15 21:41:21 PDT 2021
I am trying to run some GDAL operations inside my Anaconda environment.
However once I upgraded my gdal and other packages the program crashed.
Environment: Anaconda
Package Version Channel
GDAL 3.3.0 pipwin
fiona 1.8.20 pipwin
geopandas 0.9.0 pipwin
shapely 1.7.1 pipwin
pyproj 2.6.1.post1 py37hcfa1391_1
Here is the offending code.
crsGeo = osgeo.osr.SpatialReference()
crsGeo.ImportFromEPSG(int(proj_type))
t = osgeo.osr.CoordinateTransformation(crs, crsGeo)
(lat, long, z) = t.TransformPoint(posX, posY)<-------------------
srs = osgeo.osr.SpatialReference(wkt=prj)
And the raster's metadata.
/proj: GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AXIS["Latitude",NORTH],
AXIS["Longitude",EAST],
AUTHORITY["EPSG","4326"]]
proj type: 4326/
The code threw the following error.
*ERROR 1: PROJ: proj_create_from_database:
C:\Users\Deployment\.conda\envs\sw_py37_cv45\Library\share\proj\proj.db
lacks DATABASE.LAYOUT.VERSION.MAJOR / DATABASE.LAYOUT.VERSION.MINOR
metadata. It comes from another PROJ installation.
ERROR 1: PROJ: proj_create: unrecognized format / unknown name
ERROR 6: Cannot find coordinate operations from `GEOGCRS["WGS
84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS
84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]'
to `'
Could not calculate crsGeo spatial reference.
F:\Sliding_Windows\GeoTiff.py, line 402: TypeError Wrong number or type of
Possible C/C++ prototypes are:
OSRCoordinateTransformationShadow::TransformPoint(double [3])
OSRCoordinateTransformationShadow::TransformPoint(double [4])
[3],double,double,double)
[4],double,double,double,double)*
Based on previous posts, it seems that proj.dll is missing from some PATH
variable. My environment only has a proj_6_2.dll, and even with that added
to my system's PATH, the error persists.
I have tried to put posX and posY inside tuples/list as well, but that did
not help.
Is this a package mismatch issue? Missing dependencies issue? Or was there a
change in how TransformPoint should be called?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
