[gdal-dev] TypeError Wrong number or type of arguments for overloaded function 'CoordinateTransformation_TransformPoint'.
Paul Harwood
runette at gmail.com
Wed Jun 16 02:17:21 PDT 2021
I admit - I was just working from the nerror message ...
F:\Sliding_Windows\GeoTiff.py, line 402: TypeError Wrong number or type of
Possible C/C++ prototypes are:
OSRCoordinateTransformationShadow::TransformPoint(double [3])
suggests that it is looking for 3 coords
On Wed, 16 Jun 2021 at 10:02, Daniel Evans <Daniel.Evans at jbarisk.com> wrote:
> *However - I think you need three input coords on the transform point? *
> The Swig bindings for Python [should/used to] provide a wrapper for
> TransformPoint(), of the form TransformPoint(x, y, z=0.0) in Python terms.
> It’s one of the listed bindings on the Python API documentation:
> TransformPoint(CoordinateTransformation self, double x, double y, double
> z=0.0)
> https://gdal.org/python/osgeo.osr.CoordinateTransformation-class.html
> Looking at the autogenerated SWIG source code in the latest version of the
> repository, it looks like that particular wrapper still exists:
> SWIGINTERN void
> OSRCoordinateTransformationShadow_TransformPoint__SWIG_2(OSRCoordinateTransformationShadow
> *self,double argout[3],double x,double y,double z=0.0){
> if (self == NULL)
> return;
> argout[0] = x;
> argout[1] = y;
> argout[2] = z;
> OCTTransform( self, 1, &argout[0], &argout[1], &argout[2] );
> https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/extensions/osr_wrap.cpp#L4422
> I’ll admit none of that particularly helps solve the issue beyond saying
> “I think it should work”, though!
> *Dr Daniel Evans*
> *Software Developer*
> e: *Daniel.Evans at jbarisk.com* <Daniel.Evans at jbarisk.com>
> t: *+44 (0)1756 799919* <+44%20(0)1756%20799919>
> *www.jbarisk.com* <http://www.jbarisk.com/>
> [image: Facebook] <https://www.facebook.com/TheFloodPeople>
> [image: LinkedIn] <https://www.linkedin.com/company/jba-risk-management/>
> [image: Twitter] <https://twitter.com/JBARisk>
> [image: YouTube]
> <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> All JBA Risk Management's email messages contain confidential information
> and are intended only for the individual(s) named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by email if you have received this
> email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, England.
> *From:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *On Behalf Of *Paul
> Harwood
> *Sent:* 16 June 2021 09:52
> *To:* zerovirus123 <briansia93 at gmail.com>
> *Cc:* gdal-dev <gdal-dev at lists.osgeo.org>
> *Subject:* Re: [gdal-dev] TypeError Wrong number or type of arguments for
> Some ideas for you:
> - In the conda environment - it says that Fiona and GDAL come from the
> pipwin channel. I would try importing them from the conda-forge channel
> since I think that is more actively maintained (and by the core teams).
> This should do the trick
> conda install -c conda-forge fiona
> Also the same for pyproj
> conda install -c conda-forge pyproj
> Pyproj and OSR can work in the same app - I am doing that. You do have to
> be a bit careful about remembering that the SR objects are not
> interchangeable.
> - in the conda environment if it working correctly - you should NOT have
> to worry about proj - the correct version is and environment variables are
> loaded automatically as part of the activate command. Indeed - having other
> versions of proj.dll in the PATH will just confuse things - try removing
> them and any env variables set OUTSIDE of the conda activate command.
> I think that all of those errors are caused by this error:
> C:\Users\Deployment\.conda\envs\sw_py37_cv45\Library\share\proj\proj.db
> lacks DATABASE.LAYOUT.VERSION.MAJOR / DATABASE.LAYOUT.VERSION.MINOR
> metadata. It comes from another PROJ installation
> That command says that it is getting proj from an environment called
> sw_py_cv45. Just to ask the obvious question ... That is the environment
> that you 3expect to be using ..correct?
> The error does suggest that the environment is corrupted and the version
> of proj.dll in the env (or being found by the Python installed in the env)
> is not the same as the version of the proj.db in the share directory of the
> env. If it was me - I would probably start again from scratch - i.e.
> conda create --name test
> conda activate test
> and see what you get.
> Just as a BTW - it looks like you have a custom config of Anaconda - since
> conda usually puts the env directory in a directory called `anaconda3`. Are
> you sure that the conda config is correct?
> On Wed, 16 Jun 2021 at 05:42, zerovirus123 <briansia93 at gmail.com> wrote:
> I am trying to run some GDAL operations inside my Anaconda environment.
> However once I upgraded my gdal and other packages the program crashed.
> Environment: Anaconda
> Package Version Channel
> GDAL 3.3.0 pipwin
> fiona 1.8.20 pipwin
> geopandas 0.9.0 pipwin
> shapely 1.7.1 pipwin
> pyproj 2.6.1.post1 py37hcfa1391_1
> Here is the offending code.
> crsGeo = osgeo.osr.SpatialReference()
> crsGeo.ImportFromEPSG(int(proj_type))
> t = osgeo.osr.CoordinateTransformation(crs, crsGeo)
> (lat, long, z) = t.TransformPoint(posX, posY)<-------------------
> srs = osgeo.osr.SpatialReference(wkt=prj)
> And the raster's metadata.
> /proj: GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AXIS["Latitude",NORTH],
> AXIS["Longitude",EAST],
> AUTHORITY["EPSG","4326"]]
> proj type: 4326/
> The code threw the following error.
> *ERROR 1: PROJ: proj_create_from_database:
> metadata. It comes from another PROJ installation.
> ERROR 1: PROJ: proj_create: unrecognized format / unknown name
> ERROR 6: Cannot find coordinate operations from `GEOGCRS["WGS
> 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS
> 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]'
> to `'
> Could not calculate crsGeo spatial reference.
> OSRCoordinateTransformationShadow::TransformPoint(double [4])
> [3],double,double,double)
> [4],double,double,double,double)*
> Based on previous posts, it seems that proj.dll is missing from some PATH
> variable. My environment only has a proj_6_2.dll, and even with that added
> to my system's PATH, the error persists.
> I have tried to put posX and posY inside tuples/list as well, but that did
> not help.
> Is this a package mismatch issue? Missing dependencies issue? Or was there
> a
> change in how TransformPoint should be called?
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/4abf2a50/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/4abf2a50/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/4abf2a50/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/4abf2a50/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/4abf2a50/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/4abf2a50/attachment-0009.png>
