[gdal-dev] LJPEG Support for GDAL
Even Rouault even.rouault at spatialys.com
Wed Jun 16 10:19:22 PDT 2021
Hum, your answer confuses me. Do you have a pointer to where LJPEG is
specified, and how different it is from JPEGLS ?
Looking at MIL-STD-2500C
(https://nsgreg.nga.mil/doc/view?i=4724&month=3&day=22&year=2021), it
mentions
C5 - Lossless JPEG
C6 - reserved values that will represent a future correlated
multicomponent compression algorithm
What I can say is that the GDAL NITF driver currently doesn't handle
C5/C6 (no connection with the CharLS driver)
Even
Le 16/06/2021 à 18:56, GeodudeKid a écrit :
> LJPEG is lossless JPEG. Trying to produce a NITF that is representative of
> the Image Compression (IC) field being set to C5 or C6. C5 should be for
> LJPEG, and C6 is for JPEGLS. I was wondering if there's a separate driver
> for lossless JPEG, or if JPEGLS is a catch-all for both compression
> algorithms.
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
