[gdal-dev] Converting WFS to shapefile
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Fri Jun 18 05:35:48 PDT 2021
Run ogrinfo WFS:https://geodata.nationaalgeoregister.nl/aan/wfs
and you'll see
1: aan:aan (title: aan) (Multi Surface)
Use the typeName as it appears. Works for me with
ogr2ogr -f "ESRI Shapefile" --debug ON -s_srs "EPSG:4326" -t_srs
"EPSG:28992" "Perceel-aan.shp"
"WFS:https://geodata.nationaalgeoregister.nl/aan/wfs?service=WFS&request=GetFeature&version=2.0.0&typename=aan:aan&srsname=EPSG:4326&bbox=163049,467594,163256,468020,EPSG:28992"
-Jukka Rahkonen-
Paul Meems wrote
> Hi List,
> I'm having trouble converting the result of a WFS request to a shapefile.
> I'm using two servers, one is working the other not.
> My command for the working server:
> ogr2ogr -f "ESRI Shapefile" -s_srs "EPSG:4326" -t_srs "EPSG:28992"
> "Perceel-bbox.shp" "WFS:
> https://geodata.nationaalgeoregister.nl/kadastralekaart/wfs/v4_0?service=WFS&request=GetFeature&version=2.0.0&typename=kadastralekaartv4:perceel&srsname=EPSG:4326&outputFormat=application/json&bbox=163049,467594,163256,468020,EPSG:28992
> And the not working server:
> "EPSG:28992" "Perceel-aan.shp" "WFS:
> https://geodata.nationaalgeoregister.nl/aan/wfs?service=WFS&request=GetFeature&version=2.0.0&typename=aan&srsname=EPSG:4326&outputFormat=application/json&bbox=163049,467594,163256,468020,EPSG:28992
> I don't get an error, the file is just not created.
> The debug messages:
> WFS:
> https://geodata.nationaalgeoregister.nl/aan/wfs?SERVICE=WFS&REQUEST=GetCapabilities&version=2.0.0&srsname=EPSG:4326&bbox=163049,467594,163256,468020,EPSG:28992
> HTTP: Fetch(
> HTTP: libcurl/7.74.0-DEV OpenSSL/1.1.1i zlib/1.2.11
> WFS: Paging support with page size 15000
> WFS: No transaction support
> GDAL: GDALOpen(WFS:
> https://geodata.nationaalgeoregister.nl/aan/wfs?service=WFS&request=GetFeature&version=2.0.0&typename=aan&srsname=EPSG:4326&outputFormat=application/json&bbox=163049,467594,163256,468020,EPSG:28992,
> this=0000018A6EA691F0) succeeds as WFS.
> GDAL: GDALDriver::Create(ESRI
> Shapefile,Perceel-aan.shp,0,0,0,Unknown,0000000000000000)
> GDAL: GDALClose(WFS:
> GDAL: GDALClose(Perceel-aan.shp, this=0000018A70565430)
> GDAL: In GDALDestroy - unloading GDAL shared library.
> When I open the URL in the browser, I do get back JSON data. When I copy
> this and paste it in QGis I get the expected polygons.
> I'm not sure how I need to change my command to get this working for the
> second server as well.
> Please advice.
> With regards,
> Paul Meems
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
