[gdal-dev] Raster Attribute Table access by name and null values
Pen Swits
penswits at gmail.com
Sat Jun 19 13:59:30 PDT 2021
If I already know the column name, is there a better way to access the value
than what I'm currently doing?
For example, currently in order to get the date value of the last row, I am
looping through all columns and confirming that the column name is what I
expect, then using that index to access the value.
for column in range(rtable.GetColumnCount()):
if rtable.GetNameOfCol(column) == "Date":
last_row_date = rtable.GetValueAsString(rtable.GetRowCount()-1,
column)
And is there any way in which I can set an empty/null value that can be
applicable for all field types?
Thank you,
Pen Swits
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
