[gdal-dev] Problem with OAPIF and numeric id in the data
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Jun 21 07:01:01 PDT 2021
With this request
ogrinfo OAPIF:https://beta-paikkatieto.maanmittauslaitos.fi/kiinteisto-avoin/features/v1/ -dialect sqlite -sql "select * from RajamerkinSijaintitiedot limit 10" --debug on
ogrinfo does not use the "id" member as feature id nor does is report it as an attribute. Id exists in the data in this format
{"type":"FeatureCollection","features":[{"type":"Feature","id":12425552,"properties":{
as can be checked with https://beta-paikkatieto.maanmittauslaitos.fi/kiinteisto-avoin/features/v1/collections/RajamerkinSijaintitiedot/items?f=json&limit=10
The service that is used as reference in https://gdal.org/drivers/vector/oapif.html is having the id as string
"type" : "Feature","id" : "DENW42AL1000NscuFL",
and in this case ogrinfo does not use "id" ad fid either but at least reads it as a normal attribute
ogrinfo -al OAPIF:https://www.ldproxy.nrw.de/rest/services/kataster flurstueck --debug on
OGRFeature(flurstueck):110
id (String) = DENW42AL1000NtLGFL
I managed to get the "id" used as fid when converting data from the service at maanmittauslaitos.fi into geopackage by using -preserve_fid but for some reason today even that does not work for me.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210621/7094e24d/attachment.html>
