[gdal-dev] WMS using a Proxy
Elena Ruiz
eruiz at aplitop.com
Wed Jun 30 01:21:49 PDT 2021
Hello, I need to access the information from a WMS server through a proxy. I would need to know exactly the syntax to use the proxy, I have tried the following:
* gdalinfo "WMS:https://www.idee.es/wms/PNOA/PNOA?service=wms&request=getcapabilities" -config GDAL_HTTP_PROXY xx.xxx.x.xx:3128 -config GDAL_HTTP_PROXYUSERPWD user:password -config GDAL_HTTP_AUTH NTLM
Would it be okay with the previous syntax? Can you repeat the word --config? Do you need quotes or brackets for the IP: port or user: password? in the case of GDAL_HTTP_AUTH, how to know whether to put NTLM or BASIC? and finally, is it better to put the parameters after gdalinfo or in the system variables?
I'm waiting for your answer, regards
[https://www.aplitop.com/descargas/firma1.jpg]
Elena Ruiz
Sofware Development & Technical Support
Tel. +34 952 43 97 71
Sumatra, 9 - 29190 M?laga (Spain)
www.aplitop.com
[cid:SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png]<https://www.facebook.com/AplitopSL/> [cid:SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png] <https://twitter.com/aplitop> [cid:SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png] <https://www.linkedin.com/company/aplitop> [cid:SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png] <https://www.youtube.com/user/aplitop>
In accordance with the provisions of the European Regulation of Data Protection 2016/679 (Reglamento Europeo de Protecci?n de Datos 2016/679), we inform you that the data and the information you provide us through this medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order to answer your questions and inform you about our products. The data provided will be kept as long as it does not request its cessation and will not be transferred to third parties except in cases where there is a legal obligation. You have the right to access your personal data, correct inaccurate data or request its deletion when the data is no longer necessary for the purposes that were collected, as well as any rights recognized in the RGPD 2016/679
<https://www.aplitop.com/Event/en/358/intergeo-2019>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210630/ccdc52ea/attachment-0001.html>
Type: image/png
Desc: SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210630/ccdc52ea/attachment-0004.png>
Type: image/png
Desc: SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210630/ccdc52ea/attachment-0005.png>
Type: image/png
Desc: SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210630/ccdc52ea/attachment-0006.png>
Type: image/png
Desc: SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210630/ccdc52ea/attachment-0007.png>
