[gdal-dev] Unexpected behavior on gdal2tiles.py
erentar2002
erentar2002 at gmail.com
Tue Mar 2 08:50:04 PST 2021
Machine A:
user at machineA:~/mars$ gdal2tiles.py -z 6-8 -p geodetic -v debris.jp2
Options: {'profile': 'geodetic', 'resampling': 'average', 's_srs': None, 'zoom': '6-8', 'resume': False, 'srcnodata': None, 'tmscompatible': None, 'xyz': None, 'verbose': True, 'exclude_transparent': None, 'quiet': None, 'nb_processes': None, 'tilesize': 256, 'kml': False, 'url': '', 'webviewer': 'all', 'title': 'debris.jp2', 'copyright': '', 'googlekey': 'INSERT_YOUR_KEY_HERE', 'bingkey': 'INSERT_YOUR_KEY_HERE', 'mapml_template': None, 'processes': 1}
Input: debris.jp2
Output: debris
Cache: 1604.5949211120605 MB
Begin tiles details calc
Input file: ( 29232P x 20669L - 4 bands)
NODATA: []
Preprocessed file: ( 29232P x 20669L - 4 bands)
ERROR 1: PROJ: proj_create_operations: Source and target ellipsoid do not belong to the same celestial body
ERROR 6: Cannot find coordinate operations from `GEOGCRS["GCS_Mars_2000",DATUM["D_Mars_2000",ELLIPSOID["Mars_2000_IAU_IAG",3396190,169.894447223612,LENGTHUNIT["metre",1,ID["EPSG",9001]]]],PRIMEM["Reference_Meridian",0,ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]]]' to `EPSG:4326'
File "/usr/bin/gdal2tiles.py", line 3242, in sys.exit(main(sys.argv)) File "/usr/bin/gdal2tiles.py", line 3234, in
main single_threaded_tiling(input_file, output_folder, options) File
"/usr/bin/gdal2tiles.py", line 3154, in single_threaded_tiling conf,
tile_details = worker_tile_details(input_file, output_folder, options)
File "/usr/bin/gdal2tiles.py", line 3070, in worker_tile_details
gdal2tiles.open_input() File "/usr/bin/gdal2tiles.py", line 1742, in
open_input self.warped_input_dataset =
update_alpha_value_for_non_alpha_inputs( File "/usr/bin/gdal2tiles.py",
line 1061, in update_alpha_value_for_non_alpha_inputs if
warped_vrt_dataset.RasterCount in [1, 3]: AttributeError: 'NoneType'
object has no attribute 'RasterCount'
Machine B:
user at machineB:~/mars$ gdal2tiles.py -z 6-8 -p geodetic -v debris.jp2
Options: {'profile': 'geodetic', 'resampling': 'average', 's_srs': None, 'zoom': '6-8', 'resume': False, 'srcnodata': None, 'tmscompatible': None, 'xyz': None, 'verbose': True, 'exclude_transparent': None, 'quiet': None, 'nb_processes': None, 'tilesize': 256, 'kml': False, 'url': '', 'webviewer': 'all', 'title': 'debris.jp2', 'copyright': '', 'googlekey': 'INSERT_YOUR_KEY_HERE', 'bingkey': 'INSERT_YOUR_KEY_HERE', 'processes': 1}
Input: debris.jp2
Output: debris
Cache: 384.14570236206055 MB
NODATA: []
ERROR 1: PROJ: proj_create_from_database: /home/user/OTB-7.2.0-Linux64/share/proj/proj.db lacks DATABASE.LAYOUT.VERSION.MAJOR / DATABASE.LAYOUT.VERSION.MINOR metadata. It comes from another PROJ installation.
Projected file: tiles.vrt ( 29232P x 20669L - 4 bands)
KML autotest OK!
Bounds (output srs): 77.42551250577 18.429672337269487 77.47613730177316 18.465467490135833
Bounds (latlong): 77.42551250577002 18.429672337269487 77.47613730177316 18.465467490135833
Generating Base Tiles:
Tiles generated from the max zoom level:
dataBandsCount: 3
tilebands: 4
1 / 1 debris/8/183/77.png
Native Extent (querysize 76443 ): (0, 0, 29232, 20669) (47211, 705631, 29232, 20669)
Tiles details calc complete.
ReadRaster Extent: (0, 0, 29232, 20669) (59, 889, 36, 26)
Generating Overview Tiles:
01 / 2 debris/7/91/38.png
build from zoom 8 tiles: (182, 76) (183, 76) (182, 77) (183, 77)
2 / 2 debris/6/45/19.png
build from zoom 7 tiles: (90, 38) (91, 38) (90, 39) (91, 39)
Why does this succeed in machine B and fail in machine A with identical
inputs?
both machines run fresh copies of gdal-bin 3.2.1+dfsg-1+b1 amd64 from
debian sid.
machine B is my desktop and machine A is a headless server.
will provide more information as asked.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210302/1430f192/attachment.html>
