[gdal-dev] problem: gdal_grid, output ers raster file
Ron Palmer ron.palmer at pgcgroup.com.au
Wed Mar 3 14:24:11 PST 2021
Thanks Even for the follow up and description of the work-around, will
try it right now.
Ron
On 4/03/2021 8:11 am, Even Rouault wrote:
> Hi,
> This is a "well known" behaviour of gdal_grid in which it writes
> raster with a bottom-left corner origin, whereas most other GDAL
> utilities use a top-left corner origin. The ERS driver doesn't support
> such convention. The workaround you can use is to output gdal_grid as
> a TIFF (tmp.tif), then use "gdalwarp tmp.tif out.ers" to flip the
> origin to a top-left one.
> Even
> Le 03/03/2021 à 22:55, Ron Palmer a écrit :
>> Looks to me like the ERMapper ERS driver has a bug, using the bottom
>> left corner to georef the raster, instead of top left. I can only use
>> it if I use local coordinates, any negative northings are plotted
>> towards the north. ERS is the main raster format I use.
>> I am happy to assist in sorting out the ERS format if the person
>> behind it is willing to have a look at it.
>> Thanks,
>> Ron
>> On 17/02/2021 4:55 pm, Ron Palmer wrote:
>>> I am having issues with outputting ers raster file from gdal_grid. I
>>> import a csv as shape, then grid it and output as ers. The Y coords
>>> are all negative as it is in fact a section I simply grid as a 2D
>>> raster. Although the shape file plots as I expect it, the ers is
>>> flipped upside-down, and hung at the lowest Y value. Please note, if
>>> I use GS7BG it works fine.
>>> How do I get an ERS output that matches the shape file/data points?
>>> I have created a simple example... however, I am new to GDAL, and
>>> this is my first post, so please let me know if there is anything
>>> else I should provide.
>>> Thanks
>>> Ron
>>> These are the commands:
>>>   711  ogr2ogr -f "ESRI Shapefile" xc_zc.shp new.csv -oo
>>> X_POSSIBLE_NAMES=xc -oo Y_POSSIBLE_NAMES=zc
>>>   712  gdal_grid -zfield Value -a linear:radius=5 xc_zc.shp -of ERS
>>> xc_zc.ers
>>> here is the content of the data
>>> xc,zc,Value
>>> 1.25,-0.625,5
>>> 3.75,-0.625,5
>>> 6.25,-0.625,5
>>> 8.75,-0.625,5
>>> 11.25,-0.625,5
>>> 1.25,-1.938,4
>>> 3.75,-1.938,4
>>> 6.25,-1.938,4
>>> 8.75,-1.938,4
>>> 11.25,-1.938,4
>>> 1.25,-3.381,3
>>> 3.75,-3.381,3
>>> 6.25,-3.381,3
>>> 8.75,-3.381,3
>>> 11.25,-3.381,3
>>> 1.25,-4.969,2
>>> 3.75,-4.969,2
>>> 6.25,-4.969,2
>>> 8.75,-4.969,2
>>> 11.25,-4.969,2
>>> 1.25,-6.716,1
>>> 3.75,-6.716,1
>>> 6.25,-6.716,1
>>> 8.75,-6.716,1
>>> 11.25,-6.716,1
>>> I have attached a jpg of my output (not sure whether the mailing
>>> list allows attachments...)
>>> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
>>> 	Virus-free. www.avg.com
>>> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>> *Ron Palmer*MSc MBA
>> Principal Geophysicist
>> 0413 579 099 ron.palmer at pgcgroup.com.au
>> www.pgcgroup.com.au <URL:www.pgcgroup.com.au>
>> */PGC Geophysics - We specialise in Electrical Surveys!/*
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
*Ron Palmer*MSc MBA
This email has been checked for viruses by AVG.
https://www.avg.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210304/f152c5c0/attachment-0001.html>
