[gdal-dev] GML duplicated FID
Martin Landa landa.martin at gmail.com
Thu Mar 4 13:42:04 PST 2021
Dear Even,
čt 4. 3. 2021 v 22:37 odesílatel Even Rouault
<even.rouault at spatialys.com> napsal:
first of all, thanks for quick reply!
> You can't probably fix this by using CopyLayer(). But if you use
> GDALVectorTranslate() with the -unsetFid option, that should solve your
> issue.
Thanks for a hint!
> It would be also good that you file an issue with a minimum reproducer
> file. The GML driver should be ideally be smarter in the way it
> generates FID to avoid this.
Here it is [1]. Should I report it as a Github issue?
Martin
[1] http://geo102.fsv.cvut.cz/~landa/tmp/data_CZ.gml.7z
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
