[gdal-dev] Failure with osr.CoordinateTransformationOptions()
Even Rouault
even.rouault at spatialys.com
Fri Mar 5 03:11:19 PST 2021
Stefano,
urn:ogc:def:coordinateOperation:EPSG::1169 is a transformation between
EPSG:4265 (the geographic CRS of Monte Mario) and EPSG:4326. You cannot
use it directly when the source CRS is EPSG:3003, which is a projected
CRS based on EPSG:4265.
You could instead use
options.SetOperation("""+proj=pipeline
+step +inv +proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0
+ellps=intl
+step +proj=push +v_3
+step +proj=cart +ellps=intl
+step +proj=helmert +x=-225 +y=-65 +z=9
+step +inv +proj=cart +ellps=WGS84
+step +proj=pop +v_3
+step +proj=unitconvert +xy_in=rad +xy_out=deg
+step +proj=axisswap +order=2,1""")
as suggested by the output of projinfo -s EPSG:3003 -t EPSG:4326
--spatial-test intersects
Even
Le 05/03/2021 à 09:42, Stefano Iacovella a écrit :
> Hi all,
> I am trying to use GDAL, via Python bindings, to convert coordinates.
> I would like to select a specific transformation when converting among
> CRS with different Datums. Reading the documentation my understanding
> is that I need to create a osr.CoordinateTransformation with options
> parameter valorized properly.
> I am using binaries from OSGEO4WIN, the release are 3.1.4 for GDAL and
> 6.3.2 for PROJ
> This is a code snippet I am using to debug:
> from osgeo import ogr
> from osgeo import osr
> source = osr.SpatialReference()
> source.ImportFromEPSG(3003)
> target = osr.SpatialReference()
> target.ImportFromEPSG(4326)
> options = osr.CoordinateTransformationOptions()
> options.SetOperation("urn:ogc:def:coordinateOperation:EPSG::1169")
> transform = osr.CoordinateTransformation(source, target, options)
> point = ogr.CreateGeometryFromWkt("POINT (1622987 4756952)")
> point.Transform(transform)
> print point.ExportToWkt()
> I have no errors running it but the coordinates of the point, after
> the transformation, are infinite. If I create the
> CoordinateTransformation without options like this:
> transform = osr.CoordinateTransformation(source, target)
> The point coordinates after transformation are ok but of course the
> conversion is performed using the Coordinate Operation automatically
> selected by the system.
> Am I doing something wrong?
> Thank you in advance for your help.
> All the best,
> Stefano
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210305/4830368c/attachment.html>
