[gdal-dev] building gdal-3.3.0-dev with proj free(): invalid pointer
Even Rouault even.rouault at spatialys.com
Sun Mar 7 11:58:02 PST 2021
Chris,
> two version of libproj are involved:
> chris at jacie:~$ ldd /usr/local/bin/gdalinfo | grep libproj
> libproj.so.22 => /usr/local/lib/libproj.so.22 (0x00007f3a6cecc000)
> libproj.so.19 => /usr/local/lib/libproj.so.19 (0x00007f3a659da000)
That's definitely the cause of the crash. It is illegal for a process to
link to several versions of libproj. You need to make sure that your
GDAL dependencies link against the same libproj version. You likely need
to rebuild libspatialite or libgeotiff (if using external libgeotiff)
against the newer PROJ version
Even
http://www.spatialys.com
