[gdal-dev] clipping with an irregular polygon with gdal.VectorTranslate
Brad Hards bradh at frogmouth.net
Sun Mar 7 21:39:08 PST 2021
Perhaps
ogr2ogr -clipsrc polygon.shp -f MVT....
If that doesn't do what you want, you might need to provide more info, including a full description of the source data, the clipping
polygon you want to use, what you expect to happen, and what happens instead.
Brad
