[gdal-dev] ZSTD compression level 17 smaller than 18+?
Tobias Wendorff
tobias.wendorff at tu-dortmund.de
Tue Mar 16 11:23:43 PDT 2021
Am 15.03.2021 um 05:04 schrieb Matt.Wilkie at yukon.ca:
>> Here's my results:
I'm also using zstd for lots of stuff. It's really performing very well.
But it often behaves totally unpredictably. For example, I get a better
compression ratio with SQL files in level 1 than with level 3. And level
6 is significantly slower than level 4 with the same compression ratio.
But overall performance is always better than its competitors.
