[gdal-dev] Question Regarding Custom gdal_translate
mat data matrixtempnew at gmail.com
Fri Mar 19 02:19:51 PDT 2021
I am required to edit a portion of gdal_translate utility to fit my own
needs. For that reason I would need to edit the code in gdal_translate
related cpp files. And redo the whole "make" command many times. Is there a
way so I can specifically test only gdal_translate functionality. So I
don't have to compile the GDAL project many times to test my custom code.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210319/b054169c/attachment.html>
