[gdal-dev] BAG Driver - dimension size being written in the wrong order
Even Rouault even.rouault at spatialys.com
Fri Mar 19 10:22:32 PDT 2021
Eric,
I believe you're right. I've just fixed the issue by changing the
template resource XML file used by the GDAL driver in
https://github.com/OSGeo/gdal/commit/1d2e7bc8fcde059de853335fee390479d457be06
So you can easily workaround the issue by updating this file in your
existing installation.
For a next time, better file an issue at
https://github.com/OSGeo/gdal/issues however. This will minimize the
risk that your report is lost because nobody was able to address it at
the very moment where they read it.
Even
Le 19/03/2021 à 17:51, Eric Younkin - NOAA Federal via gdal-dev a écrit :
> Hello,
> Using conda installed GDAL 3.2.1
> I think I've stumbled on a bug with the BAG driver.  It seems as
> though when you use Create() to make a BAG, it writes the
> dimensionSize xml attribute in the wrong order.  It sets the column
> dimension size to the row dimensionSize xml attribute, and row to
> column.  I found this on examining the xml manually, see blob below.
> <gmd:axisDimensionProperties>
>         <gmd:MD_Dimension>
>           <gmd:dimensionName>
>             <gmd:MD_DimensionNameTypeCode
> codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_DimensionNameTypeCode
> <http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_DimensionNameTypeCode>"
> codeListValue="row">row</gmd:MD_DimensionNameTypeCode>
>           </gmd:dimensionName>
> *          <gmd:dimensionSize>
>             <gco:Integer>546</gco:Integer>
>           </gmd:dimensionSize>*
>           <gmd:resolution>
>             <gco:Measure uom="m">2.0</gco:Measure>
>           </gmd:resolution>
>         </gmd:MD_Dimension>
>       </gmd:axisDimensionProperties>
> This bug does not affect viewing the BAG in QGIS, as it seems like
> QGIS just computes the size using the actual array.  I found that GDAL
> created BAGs would not load in Caris, a software for viewing
> bathymetric data.  I believe that is because Caris is using the
> dimensionSize xml instead of calculating size from the data.  If I
> swap row/col dimensionSize, the BAG then works in Caris.
> Seems like a relatively simple fix (assuming I am right about this),
> please let me know if I need to submit it somewhere else.
> Thanks,
> Eric
> Eric Younkin
> Physical Scientist
> NOAA OCS, Hydrographic Systems and Technology Branch
> 1315 East-West Highway
> N/CS11, Room 6604
> Silver Spring, MD 20910
> Office: 240-847-8208
> Cell: 828-331-8197
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210319/37b4c70d/attachment.html>
