[gdal-dev] OAPIF with Accept-encoding: gzip
Even Rouault
even.rouault at spatialys.com
Tue Mar 23 07:02:41 PDT 2021
Hi Jukka,
Accept-Encoding: gzip is actually sent by default as you can see with
"ogrinfo
OAPIF:"https://beta-paikkatieto.maanmittauslaitos.fi/inspire-buildings/features/v1/collections/building/"
--debug on --config CPL_CURL_VERBOSE YES", and the server honors it:
> GET
/inspire-buildings/features/v1/collections/building/items?f=json&limit=10
HTTP/1.1
Host: beta-paikkatieto.maanmittauslaitos.fi
Accept: application/geo+json, application/json
< HTTP/1.1 200 OK
< Content-Encoding: gzip
< Content-Type: application/geo+json
Curl automatically uncompress the data, so this is transparent for GDAL.
The debug trace "HTTP: These HTTP headers were set" is a bit misleading
as it only displays the HEADERS option sent to CPLHttpFetch(), but not
the content of what is specified with the GDAL_HTTP_HEADER_FILE config
option. Enabling Curl traces with CPL_CURL_VERBOSE=YES is the ultimate
way of seeing what is really sent to the server.
Even
Le 23/03/2021 à 13:21, Rahkonen Jukka (MML) a écrit :
> Hi,
> Is it possible to ask the OAPIF server to send response as gzipped,
> and if it succeeds, would GDAL know what to do with the response? I
> made a try by saving a line “Accept-Encoding: gzip" as a test file and
> then making this request:
> ogrinfo
> --config GDAL_HTTP_HEADER_FILE headers.txt --debug on --config
> cpl_debug on
> Unfortunately it seems that Accept-Encoding header was not added:
> HTTP: These HTTP headers were set: Accept: application/geo+json,
> application/json
> Is there some trick to make this to work or would it require changes
> into the OAPIF driver?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210323/50324593/attachment.html>
