[gdal-dev] BAG Driver - dimension size being written in the wrong order
Even Rouault
even.rouault at spatialys.com
Tue Mar 23 14:20:08 PDT 2021
For posterity: just to note that the below fix turned out to be incorrect
See https://github.com/OSGeo/gdal/issues/3605 for more details and the
appropriate fix
Even
Le 19/03/2021 à 18:22, Even Rouault a écrit :
> Eric,
> I believe you're right. I've just fixed the issue by changing the
> template resource XML file used by the GDAL driver in
> https://github.com/OSGeo/gdal/commit/1d2e7bc8fcde059de853335fee390479d457be06
> So you can easily workaround the issue by updating this file in your
> existing installation.
> For a next time, better file an issue at
> https://github.com/OSGeo/gdal/issues however. This will minimize the
> risk that your report is lost because nobody was able to address it at
> the very moment where they read it.
> Even
> Le 19/03/2021 à 17:51, Eric Younkin - NOAA Federal via gdal-dev a écrit :
>> Hello,
>> Using conda installed GDAL 3.2.1
>> I think I've stumbled on a bug with the BAG driver. It seems as
>> though when you use Create() to make a BAG, it writes the
>> dimensionSize xml attribute in the wrong order. It sets the column
>> dimension size to the row dimensionSize xml attribute, and row to
>> column. I found this on examining the xml manually, see blob below.
>> <gmd:axisDimensionProperties>
>> <gmd:MD_Dimension>
>> <gmd:dimensionName>
>> <gmd:MD_DimensionNameTypeCode
>> codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_DimensionNameTypeCode
>> <http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_DimensionNameTypeCode>"
>> codeListValue="row">row</gmd:MD_DimensionNameTypeCode>
>> </gmd:dimensionName>
>> * <gmd:dimensionSize>
>> <gco:Integer>546</gco:Integer>
>> </gmd:dimensionSize>*
>> <gmd:resolution>
>> <gco:Measure uom="m">2.0</gco:Measure>
>> </gmd:resolution>
>> </gmd:MD_Dimension>
>> </gmd:axisDimensionProperties>
>> This bug does not affect viewing the BAG in QGIS, as it seems like
>> QGIS just computes the size using the actual array. I found that
>> GDAL created BAGs would not load in Caris, a software for viewing
>> bathymetric data. I believe that is because Caris is using the
>> dimensionSize xml instead of calculating size from the data. If I
>> swap row/col dimensionSize, the BAG then works in Caris.
>> Seems like a relatively simple fix (assuming I am right about this),
>> please let me know if I need to submit it somewhere else.
>> Thanks,
>> Eric
>> Eric Younkin
>> Physical Scientist
>> NOAA OCS, Hydrographic Systems and Technology Branch
>> 1315 East-West Highway
>> N/CS11, Room 6604
>> Silver Spring, MD 20910
>> Office: 240-847-8208
>> Cell: 828-331-8197
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210323/61c12ae9/attachment.html>
