[gdal-dev] interpreting gdalcompare results
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Thu Mar 25 04:01:41 PDT 2021
There is some documentation in https://gdal.org/programs/gdalcompare.html:
Synopsis:
gdalcompare.py [-sds] golden_file new_file
<golden_file>
The file that is considered correct, referred to as the golden file.
<new_file>
The file being compared to the golden file, referred to as the new file.
In your report the golden file (call is as the first file if it feels
better) has zero overview levels and the second file has 5 overview levels.
At pixel level there are no differences. The script does not inform about
similarities. You can also have a look at the comments in the script itself.
You can find it from your computer and from GitHub
https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/osgeo/utils/gdalcompare.py.
-Jukka Rahkonen-
mhw-at-yg wrote
> Hi,
> How do I find out more info on what the differences are from gdalcompare?
> What does "New: n" mean?
> $ gdalcompare source-image.tif xxx-001.tif
> Files differ at the binary level.
> Band 1 overview count difference:
> Golden: 0
> New: 5
> Band 2 overview count difference:
> Golden: 0
> New: 5
> Band 3 overview count difference:
> Golden: 0
> New: 5
> Differences Found: 4
> I've used raster math to subtract one image from the other and the result
> is zero in all pixels.
> Matt Wilkie
> Geomatics Analyst
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | Yukon.ca<http://yukon.ca/>
> Hours: 08:30-16:30, Tue-Wed: Office, Thu-Fri: Remote.
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
