[gdal-dev] Adding gcps to a raster using gdal_translate can result in data loss.
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Fri Mar 26 13:59:36 PDT 2021
Please give an exact example. Preferably with a raster that can be created
from command line with gdal_create followed by other required commands. Or
alternatively Python code that re-produces the issue.
-Jukka Rahkonen-
Hays Barrett wrote
> If the gcps stretch the image beyond the dimensions of the original raster
> it appears to clip the data that sits outside of the original raster
> dimensions rather than increase the raster dimensions to fit the stretched
> data .
> Is this the expected behavior?
> If so is there a way to increase the dimensions of a raster so there is no
> data loss?
> Thanks,
> -Hays
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
