[gdal-dev] Where is the projection info stored in a GDAL dataset?
Even Rouault even.rouault at spatialys.com
Sun Mar 28 11:14:15 PDT 2021
Joaquim,
ogr2ogr -t_srs passes the CRS object as an argument of the
GDALDataset::CreateLayer() API
GDALDataset::SetProjection() / GDALSetProjection() is (at least in all
implementations of in-tree drivers) reserved for the raster API, and
raster drivers that support the Create() API.
Similarly GDALDataset::GetSpatialRef() / GDALGetSpatialRef() is for the
raster API
For the vector API, use OGRLayer::GetSpatialRef() (different layers in a
same dataset could have different CRS)
Best regards,
Even
Le 28/03/2021 à 19:57, Joaquim Manuel Freire Luís a écrit :
> Hi,
> I am trying to use the GDAL shared lib directly from Julia and there
> are things that keep breaking my head. For example, the lines below
> use a mix of GMT and GDAL wrapper functions calls that *WORK*. First
> command creates a GMT dataset with two UTM points type with an
> assigned coordinate system. Next, in 2), I create a GDAL dataset of a
> LineString, convert it to geog in 3) and save it to file using the
> OGR_GMT driver in 4)
> 1) D2 = mat2ds([588977.324434907 4095339.69117669; 579551.921920776
> 4150721.71333039], proj="+proj=utm +zone=29");
> 2) ds = gmt2gd(D2);
> 3) ds2=ogr2ogr(ds, ["-t_srs", "+proj=longlat", "-overwrite"])
> 4) ogr2ogr(ds2, dest="lixo2.gmt")
> Now the troubles. When I tried to use GDALSetProjection() I got an
> error like this
> ERROR 6: /vsimem/##269: Dataset does not support the SetSpatialRef()
> method.
> So I found that I could set the CRS with GDALDatasetCreateLayer()
> while creating a layer on the dataset (using the Memory driver)
> (https://github.com/GenericMappingTools/GMT.jl/blob/master/src/gdal_utils.jl#L254
> <https://github.com/GenericMappingTools/GMT.jl/blob/master/src/gdal_utils.jl#L254>)
> But oddly trying to inquiry the **ds** with GDALGetSpatialRef()
> returns an empty pointer. I.e.:
> julia> Gdal.GDALGetSpatialRef(ds.ptr)
> Ptr{Nothing} @0x0000000000000000
> However the CSR was well sored in some place because the ="lixo2.gmt”
> is correct (it has this)
> # @VGMT1.0 @GLINESTRING
> # @R-8.1/-8/37/37.5
> # @Jp"+proj=longlat +datum=WGS84 +no_defs"
> # @Jw"GEOGCS[\"unknown\",DATUM[\"WGS_1984\",SPHEROID[\"WGS
> 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9122\"]],AXIS[\"Longitude\",EAST],AXIS[\"Latitude\",NORTH]]"
> # FEATURE_DATA
> -8 37.0
> -8.1 37.5
> But my trouble is that I want to fish the CRS from the ogr2ogr dataset
> (the ds2 above) so that I can convert back from GDAL to GMT (which I
> already can) without having to save to a file in disk.
> So basically my question is where is that CRS stored and how can I
> access it?
> Thanks
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210328/ce00ba85/attachment.html>
