[gdal-dev] Relation between PROJ8, GDAL, and national grids
Juan Pedro Pérez Alcántara
jp.perez.alcantara at gmail.com
Mon Mar 29 01:47:06 PDT 2021
Even, thanks for the answer. The symlinks to the old grid names worked as
expected. Thanks for reporting the fix to PROJ and for finally help me
understand the libraries' dependencies.
Regards,
On Sun, 28 Mar 2021 at 21:17, Even Rouault <even.rouault at spatialys.com>
wrote:
> Juan Pedro,
> the fact that the es_ign_SPED2ETV2.tif grid wasn't used turned out to be a
> PROJ issue, with a fix now queued in
> https://github.com/OSGeo/PROJ/pull/2619
> One easy workaround is that you create symbol links:
> ln -s es_ign_SPED2ETV2.tif /usr/local/share/proj/PENR2009.gsb
> ln -s es_ign_SPED2ETV2.tif /usr/local/share/proj/BALR2009.gsb
> Regarding the differences in output between gdaltransform and cs2cs, this
> is just different rounding modes of the floating point values. You can
> change the number of decimals of cs2cs with the -d {number_of_decimals}
> switch
> Even
> Le 28/03/2021 à 19:57, Juan Pedro Pérez Alcántara a écrit :
> Even, thanks for replying, and Javier, thanks for the advice about the
> list etiquette. I will not change the subject in such events.
> I'm sure it's the only PROJ installation because I'm building the
> libraries in a Docker container. I've also conducted some more tests from
> zero, I've found out I've been using some old tests I wrote some time ago
> that were outdated and faulty, sorry about that. What follows is the
> detailed actions I've taken.
> With the IGN (Spanish National Geographic Institute) geodesic calculator I
> performed a EPSG 23030 (ED50 UTM 30N) to EPSG 25830 (ETRS89 UTM 30N) shift:
> 235205.243 4142110.093 > 235094 4141906
> I take this as the target result.
> I set PROJ_LIB to /usr/local/share/proj and configured PROJ with a simple
> ./configure, no options.
> Using cs2cs:
> cs2cs EPSG:23030 EPSG:25830 > 235094.09 4141905.02
> which I suppose is a 7 parameters shift, which is great, but not perfect,
> can do better with the grid. Thus:
> cs2cs +proj=utm +zone=30 +ellps=intl +units=m +no_defs
> +nadgrids=/usr/local/share/proj/es_ign_SPED2ETV2.tif +to EPSG:25830 >
> 235094.00 4141906.00
> which nails it. Again, my fault assuming PROJ was using the grid by
> default.
> Then I compiled GDAL with another flat ./configure, it found a PROJ >= 6.
> Using gdaltransform:
> gdaltransform -s_srs EPSG:23030 -t_srs EPSG:25830 > 235094.087184815
> 4141905.01683498
> which is consistent with cs2cs. Using:
> gdaltransform -s_srs "+proj=utm +zone=30 +ellps=intl +units=m +no_defs
> +nadgrids=/usr/local/share/proj/es_ign_SPED2ETV2.tif" -t_srs EPSG:25830 >
> 235094.000297496 4141905.99963473
> which is consistent with cs2cs too.
> Then, having solved this part of the issue, I would like very much if you
> can advice me on how to "tweak" default definitions of the SRS to include
> the use of the grid by default, which would be not absolutely necessary for
> my application but a nice to have.
> Also, just out of curiosity, why are PROJ and GDAL yielding slightly
> different outputs (albeit perfectly ok both)? Is GDAL doing its own
> calculations besides PROJ? Forgive my lack of deep understanding of the
> GDAL inner architecture for I am an end user and not a developer. Just
> curious.
> Best regards,
> On Sat, 27 Mar 2021 at 21:32, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Juan Pedro,
>> > I'm at a loss trying to understand the relationship between PROJ8,
>> > GDAL, and how to use TIFF national grids. So far my findings are:
>> > - PROJ8 is installed and cs2cs uses the grid to transform, performing
>> > an extremely accurate shift;
>> > - GDAL, compile on the above PROJ8, when using
>> > gdaltransform, yields less accurate
>> There's no fundamental reason for transforms with gdaltransform being
>> less accurate than with cs2cs. You have to be much more specific with
>> the exact gdaltransform invokation you are trying. And are you really
>> sure that you use the PROJ version you think ? (check with ldd
>> libgdal.so on Linux)
>> You can also set the PROJ_DEBUG=2 and CPL_DEBUG=ON environment variables
>> and look at the traces.
>> Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> -- http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210329/de99afc2/attachment.html>
