[gdal-dev] Errors with gdalwarp in reprojection
    Hotmail
    rlelamer at hotmail.fr
    Mon Mar 29 08:24:34 PDT 2021
From a png file library (524288 tiles of 256x256px), I georeference them using gdal_translate like this :
=> gdal_translate -of VRT -a_srs EPSG: 4326 -a_nodata 255 PATH / FILE.png PATH / FILE.vrt -a_ullr ULLR
Then I use gdalwarp to reproject them like this :
=> gdalwarp -overwrite -s_srs EPSG:4326 -t_srs EPSG:3857 -co COMPRESS=LZW PATH/FILE.vrt PATH/FILE.tiff
524286 tiles, out of 524288, work without any problem but 2 gives me an error message …
The 2 .vrt files of these tiles tell me this :
Driver: VRT/Virtual Raster
Files: map_11_1023_0.vrt
       /Users/romain/VRTiles/bw_png/map_11_1023_0.png
Size is 256, 256
Coordinate System is:
GEOGCRS["WGS 84",
    DATUM["World Geodetic System 1984",
        ELLIPSOID["WGS 84",6378137,298.257223563,
            LENGTHUNIT["metre",1]]],
    PRIMEM["Greenwich",0,
        ANGLEUNIT["degree",0.0174532925199433]],
    CS[ellipsoidal,2],
        AXIS["geodetic latitude (Lat)",north,
            ORDER[1],
        AXIS["geodetic longitude (Lon)",east,
            ORDER[2],
    ID["EPSG",4326]]
Data axis to CRS axis mapping: 2,1
Origin = (179.648437500000000,90.000000000000000)
Pixel Size = (0.001373291015625,-0.001373291015625)
Corner Coordinates:
Upper Left  ( 179.6484375,  90.0000000) (179d38'54.38"E, 90d 0' 0.00"N)
Lower Left  ( 179.6484375,  89.6484375) (179d38'54.38"E, 89d38'54.38"N)
Upper Right ( 180.0000000,  90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000,  89.6484375) (180d 0' 0.00"E, 89d38'54.38"N)
Center      ( 179.8242188,  89.8242188) (179d49'27.19"E, 89d49'27.19"N)
Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
  NoData Value=255
  Image Structure Metadata:
    NBITS=1
  Color Table (RGB with 2 entries)
    0: 0,0,0,255
    1: 255,255,255,255
Files: map_11_1023_511.vrt
       /Users/romain/VRTiles/bw_png/map_11_1023_511.png
Size is 256, 256
GEOGCRS["WGS 84",
    CS[ellipsoidal,2],
            ORDER[1],
            ORDER[2],
    ID["EPSG",4326]]
Origin = (179.648437500000000,-89.648437500000000)
Corner Coordinates:
Upper Left  ( 179.6484375, -89.6484375) (179d38'54.38"E, 89d38'54.38"S)
Lower Left  ( 179.6484375, -90.0000000) (179d38'54.38"E, 90d 0' 0.00"S)
Upper Right ( 180.0000000, -89.6484375) (180d 0' 0.00"E, 89d38'54.38"S)
Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center      ( 179.8242188, -89.8242188) (179d49'27.19"E, 89d49'27.19"S)
  NoData Value=255
    NBITS=1
    0: 0,0,0,255
    1: 255,255,255,255
gdalwarp errors :
• the first one give me this :
Creating output file that is -2147483648P x 362L.
ERROR 1: Attempt to create -2147483648x362 dataset is illegal,sizes must be larger than zero.
• the second one give me this :
And I don't understand why ... what am I doing that is not correct since it works well on all the other tiles?
I use GDAL 3.2.2, released 2021/03/05
Thanks
Romain
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210329/7e8bd870/attachment-0001.html>
