[gdal-dev] Can't access to points in a buffer returned geometry with OGR_G_GetX
Even Rouault even.rouault at spatialys.com
Mon Mar 29 08:42:33 PDT 2021
OGR_G_GetX() can only work on a Point or a LineString/LinearRing
for a polygon, you need to extract the ring first with
OGR_G_GetGeometryRef() / OGR_G_GetGeometryCount()
Even
Le 29/03/2021 à 17:26, Joaquim Manuel Freire Luís a écrit :
> OK, one more from the Julia wrappers. Playing with buffers now, and it
> works but I want to get the points and that fails
> julia> wkt = "POINT (1198054.34 648493.09)";
> julia> dbf = Gdal.buffer(Gdal.fromWKT(wkt), 500)
> Geometry: POLYGON ((1198554.34 648493.09,1198553.65476738 64 ... .09))
> julia> toWKT(dbf)[1:90]
> "POLYGON ((1198554.34 648493.09,1198553.65476738
> 648466.922021879,1198551.60094768 648440.8"
> The ‘toWKT()’ function calls OGR_G_ExportToWkt()
> But now if I try to extract the points with OGR_G_GetX() it errors
> julia> Gdal.OGR_G_GetX(dbf.ptr, 0)
> ERROR 6: Incompatible geometry for operation                    #
> ç============= ????
> 0.0
> julia> Gdal.OGR_G_GetPointCount(dbf.ptr)          # ç============= Why so?
> 0
> Although the toWKT() works, tat’s an ascii representation but I want I
> want to access them in binary (not in WKB) to send to GMT.
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210329/6ca2b415/attachment.html>
