[gdal-dev] Gdal Java
paul.malm at lfv.se
paul.malm at lfv.se
Mon Mar 29 23:45:14 PDT 2021
Hi stefan,
I have not come any further...
I have copied gdalalljni.dll to C:\Program Files\OpenJDK\jdk-8.0.262.10-hotspot\jre\bin
And I have set the following environment variables:
GDAL_DATA=C:\Program Files\Gdal_321\bin\gdal-data
GDAL_DRIVER_PATH=C:\Program Files\Gdal_321\bin\gdal\plugins
JAVA_HOME=C:\Program Files\OpenJDK\jdk-8.0.262.10-hotspot\
Path=...C:\Program Files\OpenJDK\jdk-8.0.262.10-hotspot\jre\bin;
C:\Program Files\Gdal_321\bin\gdal\java;
C:\Program Files\Gdal_321\bin;
C:\Program Files\Gdal_321;
C:\Program Files\Gdal_321\bin\gdal\apps;
And when I run gdalinfo - version, I get the following messages:
C:\>gdalinfo --version
ERROR 1: Can't load requested DLL: C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_GEOR.dll
126: It is not possible to find the specified module.
ERROR 1: Can't load requested DLL: C:\Program Files\Gdal_321\bin\gdal\plugins\ogr_OCI.dll
GDAL 3.2.1, released 2020/12/29
Any ideas?
Kind regards,
Paul
Från: Malm, Paul (Operations AIM)
Skickat: den 25 mars 2021 10:38
Till: 'Stefan Moebius' <Stefan.Moebius at amdocs.com>; gdal-dev at lists.osgeo.org
Ämne: SV: Gdal Java
Hi Stefan,
Thanks for responding on my guestion for help!
-I've downloaded release-1928-x64-gdal-3-2-1-mapserver-7-6-2.zip
and unzipped it to C:\Program Files\Gdal_321.
-Then I added to the system path:
C:\Program Files\Gdal_321\bin\gdal\java and C:\Program Files\Gdal_321\bin.
-Restarted the computer.
Entered Eclipse.
-Set the Class-path to C:\Program Files\Gdal_321\bin\gdal\java\gdal.jar
-Run a simple java program with the commands:
gdalJNI jni= new gdalJNI();
if(jni.HasThreadSupport())
The error code I get is:
Native library load failed.
java.lang.UnsatisfiedLinkError: no gdalalljni in java.library.path
Exception in thread "main" java.lang.UnsatisfiedLinkError: org.gdal.gdal.gdalJNI.HasThreadSupport()I
at org.gdal.gdal.gdalJNI.HasThreadSupport(Native Method)
at org.geotools.jdbcconnection.raster.TransformRaster.<init>(TransformRaster.java:64)
at org.geotools.jdbcconnection.raster.TransformRaster.main(TransformRaster.java:51)
Then I copy the gdalalljni.dll to C:\Program Files\OpenJDK\jdk-8.0.262.10-hotspot\jre\bin\
And gets the following error code:
java.lang.UnsatisfiedLinkError: C:\Program Files\OpenJDK\jdk-8.0.262.10-hotspot\jre\bin\gdalalljni.dll: Det går inte att hitta den angivna proceduren
Both GDAL and Java are windows x64.
I would be more then grateful for further help.
/Paul
Från: gdal-dev <gdal-dev-bounces at lists.osgeo.org> För Stefan Moebius via gdal-dev
Skickat: den 24 mars 2021 09:42
Till: gdal-dev at lists.osgeo.org
Ämne: Re: [gdal-dev] Gdal Java
Klicka bara på länkar och öppna bilagor om du litar på avsändaren och vet att innehållet är säkert.
Hi Paul,
I find the binaries provided at https://url11.mailanyone.net/v1/?m=1lOzCg-0001ww-4L&i=57e1b682&c=9fNL_OAF8vCIgrjZs9aaEB2UNNImM6gI8GCzoqAnKNimVVkylHGA07tBJv6IOWRHGmUKKXljttalb7-9fSKoJRXHVHgZZReNymWKG_G2PNsxEfzkrdsDLJ5OCUF6GOAknKU4asXym3XgQgeOGIjYq6tb5x-KYwQMeTZwonVcJUyaCE6P24h0b-tnGHxFOYo8tTg_FMbjprD8DaPQsY7871SA4Agmh43T_JQ3BjKFdtcr_ELXZdLivAPNafJvPSW6 the easiest to use. If you click on one build, e.g. release-1928-x64-gdal-3-2-1-mapserver-7-6-2, you get a number of download options, including several installers. If you use the first one (Compiled binaries in a single .zip package), you get an archive which you need to extract, and which contains a folder bin\gdal\java. In there you find gdal.jar and gdalalljni.dll. Now in order to use this, you need to have
* Gdal.jar in your Java Classpath
* The extracted bin\gdal\java and bin folders in your Path (in Eclipse: Run Configuration -> Environment -> Select -> Path, then edit the value, or set in the system)
If that doesn't work, you'll need to provide some more detailed description of what issue you are facing.
Stefan
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of paul.malm at lfv.se
Sent: Dienstag, 23. März 2021 08:26
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Gdal Java
Hi list,
is there someone out there who has succeeded in installing Gdal Javabindings in Windows?
I've tried for some weeks now :( and I can't find very much information how to do it I Windows.
gdalalljni.dll is not found for starters (Gdal 3.2.0) but it is there, as installed by the installation process.
I've been asking around on internet, but without any luck.
If these is someone who knows how to do it in Windows with Eclipse, it would be much appreciated to get some info...
It would be nice to have a bullet list (for dummies), from where to get the correct download files, installation, setting environment, what is needed to be set in Eclipse etc. I don't have any experience with javabindings or C++...
Kind regards,
Paul
This email and the information contained herein is proprietary and confidential and subject to the Amdocs Email Terms of Service, which you may review at https://www.amdocs.com/about/email-terms-of-service<https://url11.mailanyone.net/v1/?m=1lOzCg-0001ww-4L&i=57e1b682&c=5keNkrDjrvzwcRXVWHrZdauN_ulzs2IpwrQsOrckW4xafxj1rhUsAUZgKUKb10efCNBee9dHzyBWSkhO6cjwaclASZKpkYv1WRfY9vsqTOkHQyXS0dczjdTZu3MRIofEcvljG4mwYuABAqCuSItDekmhYOUgTI8aLLcAwPM7y1M1vZ2hLYnNkVKEKopxHH8RC1eRVKCFSdNWtP4Q41XCZZJPHH_4RMryRb-6kS1GOYaP0Z02s9CcGMNfK1Rhoem-ADgDfyNZoG7HlIiRc0OQ7w>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210330/b34a41f9/attachment-0001.html>
