[gdal-dev] Copy or translate ?
Pierre Chatelier pierre at chachatelier.fr
Wed Mar 31 06:14:39 PDT 2021
Hello,
This a question about good practice in GDAL.
A data source provides me fixed-sized blocks of data, but the total
amount of data is not known in advance.
To store them until the "end" event, I incrementally add those blocks to
a dataset using AddBand() (supported by driver "MEM")
But once the dataset is complete, I want to reorder its data (because
what I used as X will be in fact a band, Y will become X, and band will
become Y) (and I want to store that in a ENVI BIL file for the
efficiency of an exisiting tool later in the workflow)
I have different options  :
1)for each band : RasterIO(read from MEM dataset) -> tmp buffer ->
RasterIO(write to ENVI dataset)
2)try to use gdal_translate_lib, but I will have a hard time figuring
how to build the good parameters
3)something else ?
Considering performance first, what would you recommand ?
Pierre Chatelier
