[gdal-dev] Cannot compile 3.3.0 without geos
    thomas bonfort
    thomas.bonfort at gmail.com
    Tue May  4 01:44:42 PDT 2021
It's known regression, see https://github.com/OSGeo/gdal/issues/3782
thomas
On Tue, May 4, 2021 at 10:42 AM Javier Jimenez Shaw <j1 at jimenezshaw.com>
wrote:
> Hi
> I am trying to compile the new release 3.3.0 in Ubuntu 18.04 with the
> option "--without-geos".
> The message is this:
> GEOS support disabled
> configure: error: GEOS support explicitly enabled, but geos-config could
> not be found
> I tried also changing to "--with-geo=no", with the same result. (Both
> options are equivalent, right?)
> Looking at the news, I see one entry related:
> * configure: Ensure --with-geos/sfcgal fail if unavailable.
> Should I do something different to disable geos?
> Thanks
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210504/52d5d2eb/attachment.html>
