[gdal-dev] New JP2Grok Driver for JPEG 2000
Even Rouault even.rouault at spatialys.com
Tue May 4 02:35:03 PDT 2021
Aaron,
did you bench timings using GDAL API & utilities (typically with
gdal_translate) ? The ones indicated in the PR use the utilities that
come which each library, but the integration within a GDAL driver might
have some influence on the timings.
What about single threaded usage ?
Even
Le 03/05/2021 à 16:59, Aaron Boxer a écrit :
> Hi Folks,
> I would like to draw people's attention once again to the pending JPEG
> 2000 driver PR
> https://github.com/OSGeo/gdal/pull/3449
> <https://github.com/OSGeo/gdal/pull/3449>
> which was opened 3 months ago.  Since I last posted, the driver now
> has an autotest script courtesy of Frank Warmerdam, and all tests are
> passing.
> In a nutshell, performance is 2-5 times faster than the only other
> viable open source driver, from OpenJPEG, in several common geospatial
> work flows. And performance rises by around 2X if the new HTJ2K
> entropy coder is used. The AGPL license will not work for everyone,
> which is why the driver is disabled by default.
> We've already discussed this at length in the previous thread and in
> the PR, but if you would like to see this new driver merged, please
> head over to the PR and give it a thumbs up. Or, if you don't want
> this driver merged, please share your feedback on the PR.
> Kind Regards,
> Aaron
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210504/13213e55/attachment.html>
