[gdal-dev] Gdal doesn't see NaN values as NoData?
Matt.Wilkie at yukon.ca
Wed May 5 15:10:47 PDT 2021
>> a) Why does gdalinfo not report the presence of nan? Meaning: how do I know when I will need to invoke (b)?
>It doesn't report nan as the nodata value, because the file lacks the GDAL_NODATA tiff tag set at "nan". So the issue is on the producer side.
Ok, noted. I will try trace this backward and report there.
>> b) What do I need to do so that applications will use nan as nodata?
> gdalwarp -dstnodata nan ...
>or if you want to remap nan to some other value
> gdalwarp -dstnodata -9999 ...
Wonderful, thank you.
>In most cases, you'd need to explicitly add the srcnodata value with
>-srcnodata nan , but nan is a special case. When gdalwarp finds a pixel
>at NaN value, be it the declared nodata value or not, it assumes this is
>nodata, hence you can omit -srcnodata nan. Wouldn't be true if 0 or some
>other value was the undeclared nodata value.
Hmmm. Part of me expects gdalwarp to then record it found and used undeclared nodata by setting the "nodata=nan" in the metadata. Regardless thanks for this important detail.
-Matt
