[gdal-dev] ubuntu installation issue: free(): invalid pointer, Aborted (core dumped)
    Paul Harwood
    runette at gmail.com
    Sat May  8 07:21:44 PDT 2021
All of the above - but also when I am using GDAL on Ubuntu I use Conda to
install and have not had any problems.
On Sat, 8 May 2021 at 13:59, Greg Troxel <gdt at lexort.com> wrote:
> Bryan Keith <bryandenniskeith at gmail.com> writes:
> > Hello,
> > I am trying to install GDAL on Ubuntu.  When I check the installation,
> > I get this:
> > ogrinfo --version
> > GDAL 3.2.1, released 2020/12/29
> I would ask Ubuntu.  As no one else has reported an issue like this that
> I can remember, and ogrinfo --version works in the obvious way for me,
> it's quite possible this is related to something Ubuntu did in
> packaging.
> It's also possible that it's a latent and usually harmless gdal bug that
> is being triggered by higher security settings.  So my other suggestion
> is to rebuild the package from soruce using the Ubuntu mechanisms but
> turning on debug symbols and run it under a debugger.  How to do that is
> out of scope for this list and should also be addressed to Ubuntu.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210508/7e9e30fd/attachment.html>
