[gdal-dev] Python Binding Searching for Legacy Libgdal Shared Object File
Even Rouault
even.rouault at spatialys.com
Tue May 11 08:25:36 PDT 2021
Conor,
It is likely that your GDAL python bindings need recompiling and/or your
native GDAL library and/or you are using an older GDAL python bindings
and/or native library than the one you think you are using.
Even
Le 11/05/2021 à 17:22, Conor McIndoe a écrit :
> Hi all,
> I’ve just tried to use the gdal python bindings for the first time in a couple of months and have been met with
>>> from osgeo import gdal
> ImportError: liberal.so.26: cannot open shared object file: No such file or directory
> Which, I believe, is a legacy .so file. I’m running this on Arch, and see I have liberal.so.28.0.3 in /usr/lib, and have recently updated the system and pip upgraded the package but still find it looking for the wrong file. Is this a known issue?
> Thanks,
> Conor
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
