[gdal-dev] GDAL bindings for Node.js: node-gdal-async 3.1.1
Momtchil Momtchev momtchil at momtchev.com
Fri May 14 11:01:31 PDT 2021
     Hello,
     I just published /node-gdal-async/ 3.1.1 - the latest bindings for
Node.js.
     Starting with 3.1, there is full support for TypeScript as well -
with no 'any' types - and curve geometries.
     It also features auto-completion with online help in IDEs that
support it (VSCode for example) even when using only Javascript.
     3.0 added parallel asynchronous Promise-based operations.
     It is bundled with GDAL 3.2.2 but supports rebuilding against your
own system installed GDAL.
     This project is a fork of the previous bindings, if you have
previously used /node-gdal/ or /node-gdal-next/, just keep in mind that
3.0 introduces sweeping changes (40% of the code is new) and that it
hasn't been very thoroughly tested in production environment - so any
feedback will be very welcome as I currently can afford to sink in as
much time as is needed for support.
/npm install gdal-async/ will get you 3.0.3
/npm install gdal-async at beta/ will get you 3.1.1 (with TypeScript and
curve geometries)
https://www.npmjs.com/package/gdal-async
<https://www.npmjs.com/package/gdal-async>
Momtchil Momtchev <momtchil at momtchev.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210514/cfac3ca3/attachment.html>
