[gdal-dev] Removing trailing decimals from contour labels of shape files
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Sat May 15 09:50:28 PDT 2021
You may ask help from mapserver-users for the Mapserver side. It is possible
to format the labels by expressions. See the example in
https://mapserver.org/mapfile/class.html#class
"More advanced Expressions can be used to specify the labels. Since version
6.0, there are functions available for formatting numbers:
TEXT ("Area is: " + tostring([area],"%.2f"))"
-Jukka Rahkonen-
GDAL - Dev mailing list wrote
> I tried making shape files of pressure from netcdf files using the
> following commands using gdal:
> gdal_contour -a pressure -i 4 -off 0 pressure.nc pressure.shp
> I noticed that when displaying the graph in mapserver I get label values
> such as 1010.00000000 whereas I want the labels to be whole numbers. How
> do
> I tweak this code to get whole numbers for pressure contour labels in map
> server?
> I have noticed that in the netcdf file pressure.nc that the pressure
> values
> have three trailing decimal points after them so a pressure value in the
> netcdf file will be 1010.000 instead of 1010. I also noticed that viewing
> the dbf file. Do I need to fix the netcdf file to display intergers? If so
> how do I do this?
> Thank you for your time.
> Jason Snyder
> Jason Snyder PhD
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
