[gdal-dev] RPC to geotransform converting
Denis Rykov rykovd at gmail.com
Tue May 18 14:26:46 PDT 2021
Thanks!
On Tue, May 18, 2021 at 10:57 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Denis,
> if the view angle is off-nadir, you generally need to use the -to RPC_DEM=
> option with a DEM covering the area of interest (and make sure the values
> it contains are WGS 84 ellipsoidal elevations) to get accurate results.
> Even
> Le 18/05/2021 à 22:50, Denis Rykov a écrit :
> Hi,
> I have a GeoTIF file and file with RPC information next to it (*.txt). Is
> there a way to transform this raster to a normal geotiff without
> displacement (with geotransform inside) or is it fundamentally impossible?
> I've tried to achieve it with gdalwarp but in this case the result of the
> transformation has about 5 meters (10 pixels) x-displacement (I use QGIS to
> visualize it).
> Denis
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210518/bf3827bf/attachment.html>
