[gdal-dev] Resampling causes change of max value
Even Rouault even.rouault at spatialys.com
Thu May 20 12:51:57 PDT 2021
Denis,
The maximum of nearest downsampling should be <= maximum of full resolution.
Potential explanations:
- your source file has overviews that contain completely different
values than the full resolution image.
- or perhaps your input_raster_to_resize_with_max_val_92.tiff file has a
.aux.xml with outdated stats (gdalinfo -stats doesn't regenerate stats
if already found)
Even
Le 20/05/2021 à 21:42, Denis Rykov a écrit :
> |$ gdalinfo -stats -json input_raster_to_resize_with_max_val_92.tiff |
> jq '.bands[0].metadata[""].STATISTICS_MAXIMUM' "92" $ gdal_translate
> -outsize 1% 1% input_raster_to_resize_with_max_val_92.tiff output.tif
> Input file size is 6845, 10302
> 0...10...20...30...40...50...60...70...80...90...100 - done. $
> gdalinfo -stats -json output.tif | jq
> '.bands[0].metadata[""].STATISTICS_MAXIMUM' "3149.9255371094" |I expected to get the same or at least close value as in the original
> raster. What might be the reason for that behavior?||
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210520/b1ccccdc/attachment.html>
