[gdal-dev] "OGR_SQLITE_SYNCHRONOUS" and "OGR_SQLITE_CACHE" accessible through Python bindings?
Met Bas Metabaseacc at gmail.com
Sat May 22 18:46:09 PDT 2021
Write speeds to GeoPackages appear to be going extremely slow in my use case.
GPKG/SQLite journal files are being created at the sizes of 10-25 kb
incrementally increasing the main geopackage file. This is saving on a drive
where such small incremental cause larger slowdowns, so I would like to
increase the size of these changes.
The configuration options "OGR_SQLITE_SYNCHRONOUS" and "OGR_SQLITE_CACHE"
appear relevant to increasing speed.
Is there a way in which I can set these options (limited to the scope of the
script being run) through Python?
Thank you,
M.B
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
