[gdal-dev] How to stop gdal_translate using overviews when resampling
Even Rouault
even.rouault at spatialys.com
Fri May 28 07:03:27 PDT 2021
With GDAL 3.3, you could add -oo OVERVIEW_LEVEL=NONE. See
https://gdal.org/api/raster_c_api.html?highlight=overview_level#_CPPv410GDALOpenExPKcjPPCKcPPCKcPPCKc
Le 28/05/2021 à 15:56, Jon Morris a écrit :
> Hello all,
> One of our users reported a difference in outputs after we upgraded
> from GDAL 2.2 to 3.2. Our tool is using gdal_translate to resample a
> raster from 5m to 10m and the outputs are very different.
> I'm ok with things changing between major versions, but when
> investigating, I found that the outputs also change depending on
> whether the input file has overviews. I was aware of the issue with
> gdalwarp where overviews are used as a shortcut
> (http://erouault.blogspot.com/2014/10/warping-overviews-and-warped-overviews.html
> <http://erouault.blogspot.com/2014/10/warping-overviews-and-warped-overviews.html>),
> but haven't been able to find anything similar in the docs or the code
> when it comes to gdal_translate.
> Should overviews make a difference? Is there any way to disable this
> behaviour, so the resampling is always done using the input raster and
> not the overviews?
> Thanks,
> Jon
> *Jon Morris*
> *Software Developer*
> e: *Jon.Morris at jbarisk.com* <mailto:Jon.Morris at jbarisk.com>
> t: *+44 (0)1756 799919* <tel:+44%20(0)1756%20799919>
> *www.jbarisk.com* <http://www.jbarisk.com/>
> Facebook <https://www.facebook.com/TheFloodPeople>
> LinkedIn <https://www.linkedin.com/company/jba-risk-management/>
> Twitter <https://twitter.com/JBARisk>
> YouTube <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> All JBA Risk Management's email messages contain confidential
> information and are intended only for the individual(s) named. If you
> are not the named addressee you should not disseminate, distribute or
> copy this e-mail.
> Please notify the sender immediately by email if you have received
> this email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, England.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210528/05e919d6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210528/05e919d6/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210528/05e919d6/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210528/05e919d6/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210528/05e919d6/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210528/05e919d6/attachment-0009.png>
