[gdal-dev] Add a list to MARC: gdal-dev
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Nov 1 11:19:35 PDT 2021
I am in favor of that (and the same for PROJ please:
https://lists.osgeo.org/mailman/listinfo/proj). Currently it is very
complicated to find anything using a search engine.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Mon, 1 Nov 2021 at 19:10, <Matt.Wilkie at yukon.ca> wrote:
> Hi, would you please consider adding Gdal-dev to the MARC archives?
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> I’m not an administrator, just someone who relies on the community and is
> having difficulties consulting historical data now that Nabble has
> discontinued it’s archive.
> Thank you,
> *Matt Wilkie*
> Geomatics Developer & Administrator
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | *Yukon.ca <http://yukon.ca/>*
> *Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.*
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211101/37126aea/attachment-0001.html>
