[gdal-dev] GDAL 3.4.0 RC1 available
Even Rouault
even.rouault at spatialys.com
Wed Nov 3 03:09:48 PDT 2021
Edzer,
This was indeed a PROJ 8.2.0 bug that I've fixed per
https://github.com/OSGeo/PROJ/pull/2917
I've also committed a workaround in GDAL itself that will go into 3.4.0 RC2
Even
Le 02/11/2021 à 23:02, Edzer Pebesma a écrit :
> This may have nothing to do with this RC but more with PROJ, but I
> found it while doing checks with R spatial packages against this RC.
> With a CRS shown below, calling OGRSpatialReference->GetName()
> resulted with PROJ 8.0.1 in "UTM Zone 25, Southern Hemisphere" ; with
> PROJ 8.1.1 or 8.2.0 it results in "SOURCECRS". Is this intended, or is
> there a problem with the WKT, or an issue somewhere else?
> BOUNDCRS[
> SOURCECRS[
> PROJCRS["UTM Zone 25, Southern Hemisphere",
> BASEGEOGCRS["GRS 1980(IUGG, 1980)",
> DATUM["unknown",
> ELLIPSOID["GRS80",6378137,298.257222101,
> LENGTHUNIT["metre",1,
> ID["EPSG",9001]]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433,
> ID["EPSG",9122]]]],
> CONVERSION["Transverse Mercator",
> METHOD["Transverse Mercator",
> ID["EPSG",9807]],
> PARAMETER["Latitude of natural origin",0,
> ANGLEUNIT["degree",0.0174532925199433],
> ID["EPSG",8801]],
> PARAMETER["Longitude of natural origin",-33,
> ID["EPSG",8802]],
> PARAMETER["Scale factor at natural origin",0.9996,
> SCALEUNIT["unity",1],
> ID["EPSG",8805]],
> PARAMETER["False easting",500000,
> LENGTHUNIT["metre",1],
> ID["EPSG",8806]],
> PARAMETER["False northing",10000000,
> ID["EPSG",8807]]],
> CS[Cartesian,2],
> AXIS["easting",east,
> ORDER[1],
> ID["EPSG",9001]]],
> AXIS["northing",north,
> ORDER[2],
> ID["EPSG",9001]]]]],
> TARGETCRS[
> GEOGCRS["WGS 84",
> DATUM["World Geodetic System 1984",
> ELLIPSOID["WGS 84",6378137,298.257223563,
> LENGTHUNIT["metre",1]]],
> ANGLEUNIT["degree",0.0174532925199433]],
> CS[ellipsoidal,2],
> AXIS["geodetic latitude (Lat)",north,
> ORDER[1],
> AXIS["geodetic longitude (Lon)",east,
> ORDER[2],
> USAGE[
> SCOPE["Horizontal component of 3D system."],
> AREA["World."],
> BBOX[-90,-180,90,180]],
> ID["EPSG",4326]]],
> ABRIDGEDTRANSFORMATION["Transformation to WGS84",
> METHOD["Position Vector transformation (geog2D domain)",
> ID["EPSG",9606]],
> PARAMETER["X-axis translation",0,
> ID["EPSG",8605]],
> PARAMETER["Y-axis translation",0,
> ID["EPSG",8606]],
> PARAMETER["Z-axis translation",0,
> ID["EPSG",8607]],
> PARAMETER["X-axis rotation",0,
> ID["EPSG",8608]],
> PARAMETER["Y-axis rotation",0,
> ID["EPSG",8609]],
> PARAMETER["Z-axis rotation",0,
> ID["EPSG",8610]],
> PARAMETER["Scale difference",1,
> ID["EPSG",8611]]]]
> On 01/11/2021 17:27, Even Rouault wrote:
>> Hi,
>> I have prepared a GDAL/OGR 3.4.0 release candidate.
>> Pick up an archive among the following ones (by ascending size):
>> https://download.osgeo.org/gdal/3.4.0/gdal-3.4.0rc1.tar.xz
>> https://download.osgeo.org/gdal/3.4.0/gdal-3.4.0rc1.tar.gz
>> https://download.osgeo.org/gdal/3.4.0/gdal340rc1.zip
>> A snapshot of the gdalautotest suite is also available :
>> https://download.osgeo.org/gdal/3.4.0/gdalautotest-3.4.0rc1.tar.gz
>> https://download.osgeo.org/gdal/3.4.0/gdalautotest-3.4.0rc1.zip
>> A snapshot of the documentation is at:
>> https://download.osgeo.org/gdal/3.4.0/gdal340doc.zip
>> GDAL-GRASS plugin:
>> https://download.osgeo.org/gdal/3.4.0/gdal-grass-3.4.0.tar.gz
>> NEWS at:
>> https://github.com/OSGeo/gdal/blob/v3.4.0RC1/gdal/NEWS.md
>> I'll call for a vote promoting it to final later this week if no
>> serious problems are reported before.
>> Best regards,
>> Even
http://www.spatialys.com
