[gdal-dev] Strange behavior opening CSVs
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 8 23:47:05 PST 2021
The trial with gdalinfo makes GDAL to try XYZ https://gdal.org/drivers/raster/xyz.html?highlight=xyz. It is not a bad guess at all. Ogrinfo tries CSV and finds the x, y, and val fields. I can’t say anything about the second part.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Simon Eves
Lähetetty: tiistai 9. marraskuuta 2021 2.21
Vastaanottaja: gdal dev <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] Strange behavior opening CSVs
I am currently implementing a better file identifier, and during the course of development, I unintentionally let GDAL try to GDALOpenEx() the attached trivial CSV file.
First, it reported "Ungridded dataset: At line 3, change of Y direction" (as a warning to the registered error-handler) and the returned OGRDataSource* was null.
When I tried again, it then claimed that I was trying to open the same file recursively. implying that it had, in fact, opened it, even though it never returned a valid handle, so I wouldn't have been able to close it again even if I'd wanted to.
I can reproduce the first part with gdalinfo.
This is with GDAL 3.2.2 on Ubuntu 20.04 with GCC 9.
I'll poke at the GDAL code myself when I have a bit more time.
[http://www2.omnisci.com/l/298412/2018-09-18/3sqpg/298412/61753/OmniSci_Email_Header2.png]<http://www.omnisci.com/>
Simon Eves
Senior Graphics Engineer, Rendering Group
100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
Email: simon.eves at omnisci.com<mailto:simon.eves at omnisci.com> | Cell:
+1 (415) 902-1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211109/0b539915/attachment-0001.html>
