[gdal-dev] Raster supported raster conversions
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 12 08:53:34 PST 2021
Having one of these in driver capabilities is enough:
Supports: Create() - Create writable dataset.
Supports: CreateCopy() - Create dataset by copying another.
There may be some special cases like WMS driver that according to that table supports Copy but obviously you cannot convert GeoTIFF into WMS service with GDAL but that must mean something else.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Lorenzo Di Giacomo
Lähetetty: perjantai 12. marraskuuta 2021 18.14
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Raster supported raster conversions
Hi i have a question about format conversion:
How is it possibile to know the possible conversions between formats (using gdal_translate)?
I found https://gdal.org/drivers/raster/index.html, so i guess is possible to convert from format X to format Y iff the GDAL driver of format Y has the "Creation" field to "yes" ?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211112/78b13eab/attachment.html>
