[gdal-dev] gdal issue with libcurl
Frank Chuang chuang at psi.edu
Mon Nov 15 10:53:51 PST 2021
I just installed version 3.4.0 of gdal using standard conda install, but
having error message stating libcurl version is incompatible with libgdal:
dyld: Library not loaded: @rpath/libcurl.4.dylib
  Referenced from:
/Users/chuang/opt/anaconda3/envs/gdal/lib/libgdal.30.dylib
  Reason: Incompatible library version: libgdal.30.dylib requires version
12.0.0 or later, but libcurl.4.dylib provides version 8.0.0
Abort trap: 6
Can anyone provide suggestions on how to remedy this? Can this be solved
by turning curl off when executing gdal? Thanks.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/633f9e07/attachment.html>
