[gdal-dev] ogr2ogr and WFS 2
Even Rouault
even.rouault at spatialys.com
Mon Nov 29 04:11:34 PST 2021
Hernán,
The URL you specify in the WFS: connection string isn't in general the
one of a GetFeature request, but only the endpoint of the service. When
you specify a GetFeature request, some heuristics trigger, but in WFS 2,
the COUNT parameter is interpreted as the page size, but as this server
supports paging, it is actually overridden by the page size returned by
the server (this part is a bug, addressed per
https://github.com/OSGeo/gdal/pull/4914), and anyway whatever the page
size used, it scrolls by default through the results.
If you add --config OGR_WFS_PAGING_ALLOWED NO you'll get the behavior
you expect. The above mentioned pull request also clarifies this hopefully.
Even
Le 29/11/2021 à 11:43, Hernán De Angelis a écrit :
> Dear all
> I seem to have problems understanding how ogr2ogr interacts with WFS
> and hope someone would be able to clarify.
> I have this WFS:
> https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?
> The capabilities document states that it supports WFS 1.0.0, 1.1.0 and
> 2.0.0.
> If I do:
> ogr2ogr -f GPKG test.gpkg
> "WFS:https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=stationsregistret:active_site&MAXFEATURES=100"
> I get a small and nice GPKG file very fast.
> But if I do:
> "WFS:https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=stationsregistret:active_site&COUNT=100"
> It downloads the whole layer.
> This behaviour can be seriously impractical for services exposing a
> large number of features.
> Pay attention that if I do:
> curl
> "https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=stationsregistret:active_site&COUNT=100"
> it retrieves a short document fast with just 100 features. The same of
> course if I invoke the service using WFS 1.0.0 or 1.1.0.
> What is going on here? Is it me that I misunderstood something about
> how ogr2ogr is supposed to interact with WFS services?
> Using GDAL 3.4.0, released 2021/11/04. But the same behaviour was
> observed in 3.3.2.
> Thanks in advance for any clarification
> Hernán
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211129/688a3462/attachment.html>
