[gdal-dev] How to access remote data that requires authentication?
Even Rouault even.rouault at spatialys.com
Tue Oct 5 09:32:04 PDT 2021
The mention to _netrc is weird...
Regarding authentication issues, this service is quite annoying and
requires enabling cookies. See
https://lists.osgeo.org/pipermail/gdal-dev/2021-October/054728.html
You need to add things like /--config GDAL_HTTP_COOKIEFILE
/tmp/cookies.txt --config//GDAL_HTTP_COOKIEJAR /tmp/cookies.txt/
Le 05/10/2021 à 18:20, Joaquim Manuel Freire Luís a écrit :
> OK, tried more things from that thread.
> gdalinfo /vsicurl/https://data.lpdaac.earthdatacloud.nasa.gov/lp-prod-protected/HLSL30.020/HLS.L30.T10TEK.2021192T184511.v2.0/HLS.L30.T10TEK.2021192T184511.v2.0.B04.tif --config GDAL_DISABLE_READDIR_ON_OPEN EMPTY_DIR --config CPL_CURL_VERBOSE ON --config CPL_VSIL_CURL_USE_HEAD FALSE
> * Couldn't find host data.lpdaac.earthdatacloud.nasa.gov in the _netrc file; using defaults ...
> OK, right it's not there.
> But latter down it says
> * Couldn't find host urs.earthdata.nasa.gov in the _netrc file; using defaults
> Now this is not right.
> < HTTP/1.1 401 Unauthorized
> < WWW-Authenticate: Basic realm="Please enter your Earthdata Login credentials. If you do not have a Earthdata Login, create one at https://urs.earthdata.nasa.gov//users/new"
> ERROR 11: HTTP response code: 401
> So I'm back to the Authentication problem. I do have an _netrc file (and .netrc btw) in my home dir as well as current dir but it does seem to find it. Is there something else that I must to in order to that file be found/used?
> -----Original Message-----
> From: thomas bonfort <thomas.bonfort at gmail.com>
> Sent: Tuesday, October 5, 2021 4:31 PM
> To: Joaquim Manuel Freire Luís <jluis at ualg.pt>
> Subject: Re: [gdal-dev] How to access remote data that requires authentication?
> for the 206 there seems to be a similar issue posted here a few days ago, search for "Problem accessing NASA Cloud Optimized GeoTIFF data"
> in the archives
> On Tue, Oct 5, 2021 at 5:26 PM Joaquim Manuel Freire Luís <jluis at ualg.pt> wrote:
>> you should also change your password, now you have posted it on a
>> public mailing list :/
>> Shit, thanks for spotting it.
>> But it doesn't work with /vsicur/ neither (had tried it  before). Now
>> the error is  206
>> gdalinfo
>> /vsicurl/https://user:pass@lpdaac.earthdata.nasa.gov/lp-prod-protected
>> /HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif
>> ERROR 11: HTTP response code: 206
>> On Tue, Oct 5, 2021 at 5:12 PM Joaquim Manuel Freire Luís <jluis at ualg.pt> wrote:
>>> Hi,
>>> I’ve read a lot of the docs, tried many -co options but can’t get through this mystery.
>>> I can access the data through GMT, which uses GDAL to do this job,
>>> but can’t do it with GDAL directly
>>> gdalinfo
>>> https://user:pass@lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30
>>> .0 15/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif
>>> ERROR 1: HTTP error code : 401
>>> gdalinfo failed - unable to open 'https://jluis:abaixo0Earthdata@lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif'.
>>> So passing longin:password via url does not work either. But it does
>>> if indirectly used
>>> grdinfo
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Title: Grid imported via
>>> GDAL
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Command:
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Remark:
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Pixel node registration
>>> used [Cartesian grid]
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Grid file format: gd =
>>> Import/export through GDAL
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: x_min: 499980 x_max:
>>> 609780 x_inc: 30 name: x n_columns: 3660
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: y_min: 4390200 y_max:
>>> 4500000 y_inc: 30 name: y n_rows: 3660
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: v_min: -0.0149 v_max:
>>> 0.8833 name: z
>>> HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: scale_factor: 0.0001
>>> add_offset: 0 packed z-range: [-149,8833]
>>> +proj=utm +zone=10 +ellps=WGS84 +units=m +no_defs
>>> Joaquim
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211005/70ee1889/attachment.html>
