[gdal-dev] How to access remote data that requires authentication?
Joaquim Manuel Freire Luís
jluis at ualg.pt
Tue Oct 5 12:05:04 PDT 2021
Even, sorry to continue this.
Now is from Julia
julia> gdalinfo("/vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif")
ERROR 4: `/vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif' not recognized as a supported file format.
I saw a reference to VSIInstallCurlFileHandler() so I thought “right I need this guy too” but when I try to install it
julia> GMT.Gdal.VSIInstallCurlFileHandler()
ERROR: could not load symbol "VSIInstallCurlFileHandler":
The specified procedure could not be found.
And indeed my gdal.dll has a couple of VSIInstaller symbols but not this one (nor zip, gzip and others).
Is the “not supported file format” related to this? Shouldn’t that symbol be exported to the dll?
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Joaquim Manuel Freire Luís
Sent: Tuesday, October 5, 2021 5:59 PM
To: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] How to access remote data that requires authentication?
>The mention to _netrc is weird...
On Windows is _netrc, not .netrc
And I finally made it (twisted). The problem was that I detest where MS decides is my home dir (and all the hidden dirs stuff that it puts there) and always have had a home at “HOME=c:\j” and it’s there that libcurl (I presume) seeks for the netrc file.
Thanks for all the tips. But I still wonder how GMT manages to read the file without anything of this.
For the record if any other Windows user needs it
gdalinfo /vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif --config GDAL_DISABLE_READDIR_ON_OPEN EMPTY_DIR --config CPL_VSIL_CURL_USE_HEAD FALSE --config GDAL_HTTP_COOKIEFILE c:/TEMP/cookies.txt --config GDAL_HTTP_COOKIEJAR c:/TEMP/cookies.txt
Driver: GTiff/GeoTIFF
Files: /vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif
Size is 3660, 3660
Coordinate System is:
PROJCRS["UTM Zone 10, Northern Hemisphere",
Regarding authentication issues, this service is quite annoying and requires enabling cookies. See https://lists.osgeo.org/pipermail/gdal-dev/2021-October/054728.html
You need to add things like --config GDAL_HTTP_COOKIEFILE /tmp/cookies.txt --config GDAL_HTTP_COOKIEJAR /tmp/cookies.txt
Le 05/10/2021 à 18:20, Joaquim Manuel Freire Luís a écrit :
OK, tried more things from that thread.
gdalinfo /vsicurl/https://data.lpdaac.earthdatacloud.nasa.gov/lp-prod-protected/HLSL30.020/HLS.L30.T10TEK.2021192T184511.v2.0/HLS.L30.T10TEK.2021192T184511.v2.0.B04.tif --config GDAL_DISABLE_READDIR_ON_OPEN EMPTY_DIR --config CPL_CURL_VERBOSE ON --config CPL_VSIL_CURL_USE_HEAD FALSE
* Couldn't find host data.lpdaac.earthdatacloud.nasa.gov in the _netrc file; using defaults ...
OK, right it's not there.
But latter down it says
* Couldn't find host urs.earthdata.nasa.gov in the _netrc file; using defaults
Now this is not right.
< HTTP/1.1 401 Unauthorized
< WWW-Authenticate: Basic realm="Please enter your Earthdata Login credentials. If you do not have a Earthdata Login, create one at https://urs.earthdata.nasa.gov//users/new<https://urs.earthdata.nasa.gov/users/new>"
ERROR 11: HTTP response code: 401
So I'm back to the Authentication problem. I do have an _netrc file (and .netrc btw) in my home dir as well as current dir but it does seem to find it. Is there something else that I must to in order to that file be found/used?
-----Original Message-----
From: thomas bonfort <thomas.bonfort at gmail.com><mailto:thomas.bonfort at gmail.com>
Sent: Tuesday, October 5, 2021 4:31 PM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt><mailto:jluis at ualg.pt>
for the 206 there seems to be a similar issue posted here a few days ago, search for "Problem accessing NASA Cloud Optimized GeoTIFF data"
in the archives
On Tue, Oct 5, 2021 at 5:26 PM Joaquim Manuel Freire Luís <jluis at ualg.pt><mailto:jluis at ualg.pt> wrote:
you should also change your password, now you have posted it on a
public mailing list :/
Shit, thanks for spotting it.
But it doesn't work with /vsicur/ neither (had tried it before). Now
the error is 206
gdalinfo
/vsicurl/https://user:pass@lpdaac.earthdata.nasa.gov/lp-prod-protected
ERROR 11: HTTP response code: 206
On Tue, Oct 5, 2021 at 5:12 PM Joaquim Manuel Freire Luís <jluis at ualg.pt><mailto:jluis at ualg.pt> wrote:
I’ve read a lot of the docs, tried many -co options but can’t get through this mystery.
I can access the data through GMT, which uses GDAL to do this job,
but can’t do it with GDAL directly
gdalinfo
https://user:pass@lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30
.0 15/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif
ERROR 1: HTTP error code : 401
gdalinfo failed - unable to open 'https://jluis:abaixo0Earthdata@lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif'.
So passing longin:password via url does not work either. But it does
if indirectly used
grdinfo
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Title: Grid imported via
GDAL
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Command:
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Remark:
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Pixel node registration
used [Cartesian grid]
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: Grid file format: gd =
Import/export through GDAL
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: x_min: 499980 x_max:
609780 x_inc: 30 name: x n_columns: 3660
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: y_min: 4390200 y_max:
4500000 y_inc: 30 name: y n_rows: 3660
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: v_min: -0.0149 v_max:
0.8833 name: z
HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif: scale_factor: 0.0001
add_offset: 0 packed z-range: [-149,8833]
+proj=utm +zone=10 +ellps=WGS84 +units=m +no_defs
Joaquim
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211005/4abcbd89/attachment-0001.html>
