[gdal-dev] GDAL/OGR coordinate transformations candidate operations priority
Pedro Venâncio
pedrongvenancio at gmail.com
Tue Oct 5 14:27:15 PDT 2021
Hi all,
I'm trying to understand what is the transformation used by default by
GDAL/OGR.
For instance, the transformation from EPSG:20790 to EPSG:3763 has two
candidates on PROJ:
C:\OSGeo4W>projinfo -s EPSG:20790 -t EPSG:3763
Candidate operations found: 2
Operation No. 1:
unknown id, Inverse of Portuguese National Grid + Lisbon (Lisbon) to Lisbon
(1) + Lisbon to ETRS89 (4) + Portugual TM06, 0.1 m, Portugal - mainland -
onshore.
PROJ string:
+proj=pipeline
+step +inv +proj=tmerc +lat_0=39.6666666666667 +lon_0=1 +k=1 +x_0=200000
+y_0=300000 +ellps=intl +pm=lisbon
+step +proj=hgridshift +grids=pt_dgt_DLx_ETRS89_geo.tif
+step +proj=tmerc +lat_0=39.6682583333333 +lon_0=-8.13310833333333 +k=1
+x_0=0
+y_0=0 +ellps=GRS80
WKT2:2019 string:
CONCATENATEDOPERATION["Inverse of Portuguese National Grid + Lisbon
(Lisbon) to Lisbon (1) + Lisbon to ETRS89 (4) + Portugual TM06",
SOURCECRS[
PROJCRS["Lisbon (Lisbon) / Portuguese National Grid",
BASEGEOGCRS["Lisbon (Lisbon)",
DATUM["Lisbon 1937 (Lisbon)",
ELLIPSOID["International 1924",6378388,297,
LENGTHUNIT["metre",1]]],
PRIMEM["Lisbon",-9.13190611111111,
ANGLEUNIT["degree",0.0174532925199433]],
ID["EPSG",4803]],
CONVERSION["Portuguese National Grid",
METHOD["Transverse Mercator",
ID["EPSG",9807]],
PARAMETER["Latitude of natural origin",39.6666666666667,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8801]],
PARAMETER["Longitude of natural origin",1,
ID["EPSG",8802]],
PARAMETER["Scale factor at natural origin",1,
SCALEUNIT["unity",1],
ID["EPSG",8805]],
PARAMETER["False easting",200000,
LENGTHUNIT["metre",1],
ID["EPSG",8806]],
PARAMETER["False northing",300000,
ID["EPSG",8807]]],
CS[Cartesian,2],
AXIS["easting (X)",east,
ORDER[1],
LENGTHUNIT["metre",1]],
AXIS["northing (Y)",north,
ORDER[2],
ID["EPSG",20790]]],
TARGETCRS[
PROJCRS["ETRS89 / Portugal TM06",
BASEGEOGCRS["ETRS89",
ENSEMBLE["European Terrestrial Reference System 1989
ensemble",
MEMBER["European Terrestrial Reference Frame 1989"],
MEMBER["European Terrestrial Reference Frame 1990"],
MEMBER["European Terrestrial Reference Frame 1991"],
MEMBER["European Terrestrial Reference Frame 1992"],
MEMBER["European Terrestrial Reference Frame 1993"],
MEMBER["European Terrestrial Reference Frame 1994"],
MEMBER["European Terrestrial Reference Frame 1996"],
MEMBER["European Terrestrial Reference Frame 1997"],
MEMBER["European Terrestrial Reference Frame 2000"],
MEMBER["European Terrestrial Reference Frame 2005"],
MEMBER["European Terrestrial Reference Frame 2014"],
ELLIPSOID["GRS 1980",6378137,298.257222101,
ENSEMBLEACCURACY[0.1]],
PRIMEM["Greenwich",0,
ID["EPSG",4258]],
CONVERSION["Portugual TM06",
ID["EPSG",9807]],
PARAMETER["Latitude of natural origin",39.6682583333333,
ID["EPSG",8801]],
PARAMETER["Longitude of natural origin",-8.13310833333333,
ID["EPSG",8802]],
ID["EPSG",8805]],
PARAMETER["False easting",0,
ID["EPSG",8806]],
PARAMETER["False northing",0,
ID["EPSG",8807]]],
CS[Cartesian,2],
ORDER[1],
ORDER[2],
ID["EPSG",3763]]],
STEP[
CONVERSION["Inverse of Portuguese National Grid",
METHOD["Inverse of Transverse Mercator",
ID["INVERSE(EPSG)",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]],
ID["INVERSE(EPSG)",19936]]],
STEP[
COORDINATEOPERATION["Lisbon (Lisbon) to Lisbon (1)",
VERSION["IGC-Prt"],
SOURCECRS[
CS[ellipsoidal,2],
AXIS["geodetic latitude (Lat)",north,
ORDER[1],
AXIS["geodetic longitude (Lon)",east,
ORDER[2],
ID["EPSG",4803]]],
TARGETCRS[
GEOGCRS["Lisbon",
DATUM["Lisbon 1937",
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4207]]],
METHOD["Longitude rotation",
ID["EPSG",9601]],
PARAMETER["Longitude offset",-9.13190611111111,
ID["EPSG",8602]],
OPERATIONACCURACY[0.0],
ID["EPSG",1756]]],
STEP[
COORDINATEOPERATION["Lisbon to ETRS89 (4)",
SOURCECRS[
GEOGCRS["Lisbon",
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4207]]],
TARGETCRS[
GEOGCRS["ETRS89",
ensemble",
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4258]]],
METHOD["HORIZONTAL_SHIFT_GTIFF"],
PARAMETERFILE["Latitude and longitude difference
file","pt_dgt_DLx_ETRS89_geo.tif"],
OPERATIONACCURACY[0.1],
ID["DERIVED_FROM(EPSG)",6188],
REMARK["Derived from 1129 common stations in the national
geodetic network. Residuals at 130 further test points average 0.09m,
maximum 0.30m."]]],
STEP[
ID["EPSG",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]],
ID["EPSG",19853]]],
USAGE[
SCOPE["unknown"],
AREA["Portugal - mainland - onshore."],
BBOX[36.95,-9.56,42.16,-6.19]]]
Operation No. 2:
(1) + Lisbon to ETRS89 (3) + Portugual TM06, 2.5 m, Portugal - mainland -
onshore.
PROJ string:
+proj=pipeline
+step +proj=push +v_3
+step +proj=cart +ellps=intl
+step +proj=helmert +x=-303.861 +y=-60.693 +z=103.607
+step +inv +proj=cart +ellps=GRS80
+step +proj=pop +v_3
+x_0=0
+y_0=0 +ellps=GRS80
WKT2:2019 string:
(Lisbon) to Lisbon (1) + Lisbon to ETRS89 (3) + Portugual TM06",
SOURCECRS[
ID["EPSG",4803]],
ID["EPSG",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]]],
CS[Cartesian,2],
ORDER[1],
ORDER[2],
ID["EPSG",20790]]],
TARGETCRS[
ensemble",
ID["EPSG",4258]],
ID["EPSG",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]]],
CS[Cartesian,2],
ORDER[1],
ORDER[2],
ID["EPSG",3763]]],
STEP[
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]],
STEP[
VERSION["IGC-Prt"],
SOURCECRS[
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4803]]],
TARGETCRS[
GEOGCRS["Lisbon",
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4207]]],
ID["EPSG",9601]],
ID["EPSG",8602]],
ID["EPSG",1756]]],
STEP[
COORDINATEOPERATION["Lisbon to ETRS89 (3)",
VERSION["CGC-Prt 2009 7m"],
SOURCECRS[
GEOGCRS["Lisbon",
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4207]]],
TARGETCRS[
GEOGCRS["ETRS89",
ensemble",
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4258]]],
METHOD["Geocentric translations (geog2D domain)",
ID["EPSG",9603]],
PARAMETER["X-axis translation",-303.861,
ID["EPSG",8605]],
PARAMETER["Y-axis translation",-60.693,
ID["EPSG",8606]],
PARAMETER["Z-axis translation",103.607,
ID["EPSG",8607]],
OPERATIONACCURACY[2.5],
ID["EPSG",5038],
REMARK["Derived in July 2009 from 119 common stations. Average
residual at 833 test points 2.5m, maximum 7m. Info source also gives a
Position Vector tfm which is of similar accuracy. Replaces Lisbon to ETRS89
(2) (tfm code 1997)."]]],
STEP[
ID["EPSG",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]],
ID["EPSG",19853]]],
USAGE[
SCOPE["unknown"],
Operation no. 1 uses grids and has an accuracy of about 0.1 meters,
compared to operation no. 2 that uses a Molodensky transformation and has
an accuracy of 2.5 m.
So, in theory, operation no. 1 should be used by default.
However, testing with gdaltransform:
C:\OSGeo4W>gdaltransform -s_srs EPSG:20790 -t_srs EPSG:3763
Enter X Y [Z [T]] values separated by space, and press Return.
286415 431434
*86412.5265012686 131433.856093867 0*
Using the grids on QGIS and on a web application of the institution that
has produced the NTv2 grids used on PROJ, the transformation output is
*86412.426 131434.171*
The difference is not huge, but this makes me believe that operations like
gdalwarp or ogr2ogr do not use the operation no. 1 by default. Am I right?
Could this be a bug? Or is there a way to force the operation used? How is
the decision managed by GDAL/OGR?
Thank you very much!
Best regards,
Pedro Venâncio
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211005/96f65df2/attachment-0001.html>
