[gdal-dev] GDAL/OGR coordinate transformations candidate operations priority
Even Rouault
even.rouault at spatialys.com
Tue Oct 5 16:32:44 PDT 2021
Le 06/10/2021 à 01:26, Pedro Venâncio a écrit :
> What a supersonic fix Even, thank you very much!!
> So, the default will be the use of the operation with better accuracy,
> right?
yes, due to the issue with the prime meridian, PROJ was confused and
didn't find any valid operation with the appropriate area of use, and
thus it fell back to an operation not using a grid
> Thanks Even!
> Pedro
> Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>> escreveu no dia quarta, 6/10/2021
> à(s) 00:06:
> This is a PROJ >= 7.2 bug, related to CRS with non-Greenwich prime
> meridian. Fix in https://github.com/OSGeo/PROJ/pull/2884
> <https://github.com/OSGeo/PROJ/pull/2884>
> Even
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211006/1353e1c3/attachment.html>
