[gdal-dev] ogr2ogr changes field length
Even Rouault
even.rouault at spatialys.com
Wed Oct 6 08:49:23 PDT 2021
Matteo,
When overwriting, a fresh new file/table is creating, without keeping
anything from the existing version.
You could probably just blank your target with
ogrinfo target.shp -sql "DELETE FROM target" -dialect SQLITE
and then ogr2ogr -append target.shp PG:.... -nln target
Even
Le 06/10/2021 à 17:37, matteo a écrit :
> Hi list,
> I've a script that uses ogr2ogr to copy, actually overwrite, tables
> from PG to shapfiles.
> The PG fields are all text (without a specified length) and the target
> shapefile that will be overwritten have all text field length equals
> to 254.
> When overwriting the length is changes to 80. Is there any specific
> option to keep the original field length?
> Cheers and thanks
> Matteo
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
