[gdal-dev] running PROJ-data/regenerate_index_html.py
Even Rouault
even.rouault at spatialys.com
Thu Oct 7 09:25:18 PDT 2021
I'd like to keep those images as small as possible. You could just
create a derived Docker image that installs git on top of it. Anyway, it
is not critical if you submit a PR without the updated indexes. I can
easily run the script on my end, before resyncing the CDN
Le 07/10/2021 à 18:17, Javier Jimenez Shaw a écrit :
> Hi
> On the contribution process of PROJ-data, there is a step where you
> should run "regenerate_index_html.py". For that you need GDAL, and a
> recent enough one.
> What I do is to use a docker image: osgeo/gdal:alpine-normal-latest
> (so I am sure I am up to date)
> However, the script also requires "git", that is not present in that
> docker image.
> Could we include "git" in that GDAL docker image? Is there a better
> option?
> Thanks
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211007/5b8950fc/attachment.html>
