[gdal-dev] ogr2ogr changes field length
matteo matteo.ghetta at gmail.com
Tue Oct 12 03:34:00 PDT 2021
Hi Jukka,
> GDAL has the internal default of 80 characters. GDAL users do not really need other options because fields are automatically expanded when longer strings are appended afterwards but if the shapefile is used in some other software it does happen that it is impossible to insert long strings because there is no room for that in the table. I suppose that you also know that by using the field width of 254 you are also maximizing the size of the .dbf file because it reserves the same fixed amount of disk space for each cell.
got it! Yes, I'm aware of the disk space :)
Cheers and thanks
Matteo
